Hi all so i posted on the proxmox forum, reddit and ltt forum but either got nothing or the thread has died off with no answers. So here i am before i just give up with proxmox.
Hi all, new to promox and fancied setting up a cluster. 1 node so far and already failing. Apologies for the long post but its adds context.
So i got a HP prodesk G3 400 mini - 8GB RAM (to be upgraded), i5-8500t. It should run at least the promox system without vms but im getting an issue with random reboots.
So it came with W11 installed and i ran that as a test, web browsing, light gaming etc etc for a good few hours and was fine, pretty solid. So i used the VE iso and rufus, got proxmox installed following a couple of guides (craftcomputing, jimsgarage) and all went smooth.
Went to bed and woke up to the pc cooking itself and unresponsive, power cycle and all good. Started messing with containers and a vm all seemed ok, beyond my config of those specific items then the web ui dropped again and the chassis started to warm up. Another power cycle all good.
Put W11 back on, left running all day and night, not a hiccup 40c cpu pretty stable all the way through. unraid, appears to also be stable after running for the best part of a day (loaded up the immich docker and let it process over 100k image files as a workout).
Put proxmox back on, web ui up and running, did nothing, went to bed, woke up still fine. Loaded the web ui started having a look around and boom, lock up.
Checked using ping and was unreachable, then a few minutes later it came back, so i looked around and it might be the realtek 8111 ethernet connection not playing nice. Checked the sys log however and im currently sat at 10 reboots. Ive powered it off now as it wasnt coming back and started to heat up.
Id point at hardware but 2 out of 3 OS were fine. Anyway, i couldn’t pull the syslog from the drive however this is what was loaded and running the web ui during the few reboots this morning.
Any help is much appreciated and the log is attached(linked) (trimmed for size)
Update: i tried this with the new release of proxmox ve 8.2 but still getting the same behaviour
Update 2: i put W11 back on the pc and its been up for over 2 days now. ive been remoting in and running stuff periodically. Even did as was suggested in the LTT forum of hitting with with prime95. It went fine not reboot or bluescreen. at a massive loss with this now
As a new user i cant upload the syslog but here is a snippet from before and after a reboot
Apr 13 11:53:54 apollo systemd: Inserted module ‘autofs4’
Apr 13 11:53:54 apollo systemd: systemd 252.22-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
Apr 13 11:53:54 apollo systemd: Detected architecture x86-64.
Apr 13 11:53:54 apollo systemd: Hostname set to .
Apr 13 11:53:54 apollo kernel: Lockdown: systemd: /dev/mem,kmem,port is restricted; see man kernel_lockdown.7
Apr 13 11:53:54 apollo systemd: Queued start job for default target graphical.target.
Apr 13 11:53:54 apollo systemd: Created slice system-getty.slice - Slice /system/getty.
Apr 13 11:53:54 apollo systemd: Created slice system-modprobe.slice - Slice /system/modprobe.
Apr 13 11:53:54 apollo systemd: Created slice system-postfix.slice - Slice /system/postfix.
Apr 13 11:53:54 apollo systemd: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
Apr 13 11:53:54 apollo systemd: Created slice user.slice - User and Session Slice.
Apr 13 11:53:54 apollo systemd: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
Apr 13 11:53:54 apollo systemd: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
Apr 13 11:53:54 apollo systemd: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
Apr 13 11:53:54 apollo systemd: Expecting device dev-disk-by\x2duuid-B47C\x2dE1DF.device - /dev/disk/by-uuid/B47C-E1DF…
Apr 13 11:53:54 apollo systemd: Expecting device dev-pve-swap.device - /dev/pve/swap…
Apr 13 11:53:54 apollo systemd: Reached target ceph-fuse.target - ceph target allowing to start/stop all [email protected] instances at once.
Apr 13 11:53:54 apollo systemd: Reached target ceph.target - ceph target allowing to start/stop all ceph*@.service instances at once.
Apr 13 11:53:54 apollo systemd: Reached target cryptsetup.target - Local Encrypted Volumes.
Apr 13 11:53:54 apollo systemd: Reached target integritysetup.target - Local Integrity Protected Volumes.
Apr 13 11:53:54 apollo systemd: Reached target paths.target - Path Units.
Apr 13 11:53:54 apollo systemd: Reached target slices.target - Slice Units.
Apr 13 11:53:54 apollo systemd: Reached target time-set.target - System Time Set.
Apr 13 11:53:54 apollo systemd: Reached target veritysetup.target - Local Verity Protected Volumes.
Apr 13 11:53:54 apollo systemd: Listening on dm-event.socket - Device-mapper event daemon FIFOs.
Apr 13 11:53:54 apollo systemd: Listening on lvm2-lvmpolld.socket - LVM2 poll daemon socket.
Apr 13 11:53:54 apollo systemd: Listening on rpcbind.socket - RPCbind Server Activation Socket.
Apr 13 11:53:54 apollo systemd: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
Apr 13 11:53:54 apollo systemd: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
Apr 13 11:53:54 apollo systemd: Listening on systemd-journald-audit.socket - Journal Audit Socket.
Apr 13 11:53:54 apollo systemd: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
Apr 13 11:53:54 apollo systemd: Listening on systemd-journald.socket - Journal Socket.
Apr 13 11:53:54 apollo systemd: Listening on systemd-udevd-control.socket - udev Control Socket.
Apr 13 11:53:54 apollo systemd: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
Apr 13 11:53:54 apollo systemd: Mounting dev-hugepages.mount - Huge Pages File System…
Apr 13 11:53:54 apollo systemd: Mounting dev-mqueue.mount - POSIX Message Queue File System…
Apr 13 11:53:54 apollo systemd: Mounting sys-kernel-debug.mount - Kernel Debug File System…
Apr 13 11:53:54 apollo systemd: Mounting sys-kernel-tracing.mount - Kernel Trace File System…
Apr 13 11:53:54 apollo systemd: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
Apr 13 11:53:54 apollo systemd: Starting keyboard-setup.service - Set the console keyboard layout…
Apr 13 11:53:54 apollo systemd: Starting kmod-static-nodes.service - Create List of Static Device Nodes…
Apr 13 11:53:54 apollo systemd: Starting lvm2-monitor.service - Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
Apr 13 11:53:54 apollo systemd: Starting [email protected] - Load Kernel Module configfs…
Apr 13 11:53:54 apollo systemd: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod…
Apr 13 11:53:54 apollo systemd: Starting [email protected] - Load Kernel Module drm…
Apr 13 11:53:54 apollo systemd: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore…
Apr 13 11:53:54 apollo systemd: Starting [email protected] - Load Kernel Module fuse…
Apr 13 11:53:54 apollo systemd: Starting [email protected] - Load Kernel Module loop…
Apr 13 11:53:54 apollo systemd: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
Apr 13 11:53:54 apollo systemd: Starting systemd-journald.service - Journal Service…
Apr 13 11:53:54 apollo systemd: Starting systemd-modules-load.service - Load Kernel Modules…
Apr 13 11:53:54 apollo systemd: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems…
Apr 13 11:53:54 apollo systemd: Starting systemd-udev-trigger.service - Coldplug All udev Devices…
Apr 13 11:53:54 apollo systemd: Mounted dev-hugepages.mount - Huge Pages File System.
Apr 13 11:53:54 apollo systemd: Mounted dev-mqueue.mount - POSIX Message Queue File System.
Apr 13 11:53:54 apollo systemd: Mounted sys-kernel-debug.mount - Kernel Debug File System.
Apr 13 11:53:54 apollo systemd: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
Apr 13 11:53:54 apollo kernel: pstore: Using crash dump compression: deflate
Apr 13 11:53:54 apollo systemd: Finished keyboard-setup.service - Set the console keyboard layout.
Apr 13 11:53:54 apollo systemd: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
Apr 13 11:53:54 apollo systemd: [email protected]: Deactivated successfully.
Apr 13 11:53:54 apollo systemd: Finished [email protected] - Load Kernel Module configfs.
Apr 13 11:53:54 apollo systemd: modprobe@dm_mod.service: Deactivated successfully.
Apr 13 11:53:54 apollo systemd: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
Apr 13 11:53:54 apollo systemd: Finished [email protected] - Load Kernel Module fuse.
Apr 13 11:53:54 apollo systemd: Finished [email protected] - Load Kernel Module loop.
Apr 13 11:53:54 apollo systemd: Mounting sys-fs-fuse-connections.mount - FUSE Control File System…
Apr 13 11:53:54 apollo systemd: Mounting sys-kernel-config.mount - Kernel Configuration File System…
Apr 13 11:53:54 apollo systemd: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
Apr 13 11:53:54 apollo kernel: EXT4-fs (dm-1): re-mounted 5aab04a6-ff53-4c73-980b-2747e9d639ed r/w. Quota mode: none.
Apr 13 11:53:54 apollo systemd: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
Apr 13 11:53:54 apollo systemd: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
Apr 13 11:53:54 apollo systemd: systemd-firstboot.service - First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Apr 13 11:53:54 apollo systemd: Starting systemd-random-seed.service - Load/Save Random Seed…
Apr 13 11:53:54 apollo systemd: Starting systemd-sysusers.service - Create System Users…
Apr 13 11:53:54 apollo systemd: Mounted sys-kernel-config.mount - Kernel Configuration File System.
Apr 13 11:53:54 apollo systemd: Started dm-event.service - Device-mapper event daemon.
Apr 13 11:53:54 apollo kernel: pstore: Registered efi_pstore as persistent store backend
Apr 13 11:53:54 apollo systemd: Finished systemd-random-seed.service - Load/Save Random Seed.
Apr 13 11:53:54 apollo systemd: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Apr 13 11:53:54 apollo systemd: modprobe@efi_pstore.service: Deactivated successfully.
Apr 13 11:53:54 apollo systemd: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
Apr 13 11:53:54 apollo systemd: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
Apr 13 11:53:54 apollo kernel: ACPI: bus type drm_connector registered
Apr 13 11:53:54 apollo systemd: Finished [email protected] - Load Kernel Module drm.
Apr 13 11:53:54 apollo systemd: Finished systemd-sysusers.service - Create System Users.
Apr 13 11:53:54 apollo systemd: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev…
Apr 13 11:53:54 apollo systemd-journald[324]: Journal started
Apr 13 11:53:54 apollo systemd-journald[324]: Runtime Journal (/run/log/journal/ebd36095ef8e40018464ee7246e62b79) is 8.0M, max 76.4M, 68.4M free.
Apr 13 11:53:54 apollo dmeventd[336]: dmeventd ready for processing.
Apr 13 11:53:54 apollo systemd-modules-load[325]: Inserted module ‘vhost_net’
Apr 13 11:53:54 apollo dmeventd[336]: Monitoring thin pool pve-data.
Apr 13 11:53:54 apollo systemd[1]: Starting systemd-journal-flush.service - Flush Journal to Persistent Storage…
Apr 13 11:53:54 apollo systemd: Started systemd-journald.service - Journal Service.
Apr 13 11:53:54 apollo systemd-journald[324]: Time spent on flushing to /var/log/journal/ebd36095ef8e40018464ee7246e62b79 is 6.102ms for 829 entries.
– Reboot –
Apr 13 11:55:06 apollo kernel: Linux version 6.5.11-8-pve (build@proxmox) (gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT_DYNAMIC PMX 6.5.11-8 (2024-01-30T12:27Z) ()
Apr 13 11:55:06 apollo kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.5.11-8-pve root=/dev/mapper/pve-root ro quiet
Apr 13 11:55:06 apollo kernel: KERNEL supported cpus:
Apr 13 11:55:06 apollo kernel: Intel GenuineIntel
Apr 13 11:55:06 apollo kernel: AMD AuthenticAMD
Apr 13 11:55:06 apollo kernel: Hygon HygonGenuine
Apr 13 11:55:06 apollo kernel: Centaur CentaurHauls
Apr 13 11:55:06 apollo kernel: zhaoxin Shanghai
Apr 13 11:55:06 apollo kernel: BIOS-provided physical RAM map:
Apr 13 11:55:06 apollo kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
Apr 13 11:55:06 apollo kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
Apr 13 11:55:06 apollo kernel: BIOS-e820: [mem 0x0000000000100000-0x000000008e82cfff] usable
Apr 13 11:55:06 apollo kernel: BIOS-e820: [mem 0x000000008e82d000-0x000000008fa8efff] reserved
Apr 13 11:55:06 apollo kernel: BIOS-e820: [mem 0x000000008fa8f000-0x000000008fc8efff] ACPI NVS
Apr 13 11:55:06 apollo kernel: BIOS-e820: [mem 0x000000008fc8f000-0x000000008fd0efff] ACPI data
Apr 13 11:55:06 apollo kernel: BIOS-e820: [mem 0x000000008fd0f000-0x000000008fd0ffff] usable
Apr 13 11:55:06 apollo kernel: BIOS-e820: [mem 0x000000008fd10000-0x000000009e7fffff] reserved
Apr 13 11:55:06 apollo kernel: BIOS-e820: [mem 0x00000000fe010000-0x00000000fe010fff] reserved
Apr 13 11:55:06 apollo kernel: BIOS-e820: [mem 0x00000000ff400000-0x00000000ffffffff] reserved
Apr 13 11:55:06 apollo kernel: BIOS-e820: [mem 0x0000000100000000-0x000000025f7fffff] usable
Apr 13 11:55:06 apollo kernel: NX (Execute Disable) protection: active
Apr 13 11:55:06 apollo kernel: efi: EFI v2.6 by HP
