I was learning about proxmox users and permissions. I created a user and a pool and added some vm’s to it. I then went to try and make a group, but got an error. Now when I do anything, I get the same error.
Parameter verification failed. (400)
poolid: property is not defined in schema and the schema does not allow additional properties
I have no idea what is going on. I’ve been using proxmox for a week.
I rebooted the node and that seems to have fixed the issue. I hope this was a fluke as I am assessing a few different hypervisors. When I finish, I will write a recommendation to my boss as to what hypervisor we should replace vmwere with.
FWIW, sounds like one of a few potential things noted here.
a) browser cache (clear cache & cookies, reload browser).
b) make sure you have the correct repositories configured. ie. if you are not a paid user then configure the no-subscription repo then apt update the system.
c) similar to above but with some more specific instructions.
