Hey Guys,
Trying to install ProxMox at the moment but I'm getting an error "Could not install kvm_intel: operation not supported".
Any Ideas on what could cause this?
Cheers,
-T
Hey Guys,
Cheers,
-T
What platform are you installing it on? What is your install media? CD or USB? What version of Proxmox?
I found trying to install proxmox off a USB stick to be a tooth and nail fight that i gave up on. CD install worked flawlessly.
EDIT: Might seem like a dumb suggestion but things get overlooked, make sure you have enabled virtualization in the BIOS.
HP Compaq 8000 Core 2 vPro. USB, Latest stable.
I'll try a cd and see what happens
That's a pretty old platform. It may say vPro but that's pretty broad as far as intel is concerned. You sure it supports virtualization?
Yes.
Any progress?
Managed to get it installed from a DVD. Still not quite sure what KVM_Intel is or does but it appears to be working now.
Thanks for your help mate!
No problem, glad you have it working. Been using proxmox for 2 years now and love the shit out of it.
