Proxmox GPU Passthrough, no audio
Hello! Long time listener first time caller.
I was finally able to successfully pass my GPU through to my Windows 10 VM today! However, I now have no audio when using Parsel to connect to the VM. I do get audio through Remote Desktop, but I’d really like to use Parsel for the lower latency and increased framerate.
I can’t seem to figure out how to get audio to show up in Windows. I don’t have any PCI Device or Audio Devices in Device Manager either.
I mapped the GPU and Audio controller in Proxmox
root@dell:~# lspci -ks 01:00
01:00.0 VGA compatible controller: NVIDIA Corporation TU106M [GeForce RTX 2070 Mobile] (rev a1)
        Subsystem: Dell TU106M [GeForce RTX 2070 Mobile]
        Kernel driver in use: vfio-pci
        Kernel modules: nvidiafb, nouveau
01:00.1 Audio device: NVIDIA Corporation TU106 High Definition Audio Controller (rev a1)
        Subsystem: Dell TU106 High Definition Audio Controller
        Kernel modules: snd_hda_intel
01:00.2 USB controller: NVIDIA Corporation TU106 USB 3.1 Host Controller (rev a1)
        Subsystem: Dell TU106 USB 3.1 Host Controller
        Kernel modules: xhci_pci
01:00.3 Serial bus controller: NVIDIA Corporation TU106 USB Type-C UCSI Controller (rev a1)
        Subsystem: Dell TU106 USB Type-C UCSI Controller
        Kernel modules: i2c_nvidia_gpu
Let me know what other system info I can get for you!
Thanks!
Install this on your VM
I have two VMs setup with a vGPU, similar application. I don’t even have a gpu audio chipset to pass through.
Then change parsec to this device for output, and enjoy!
That worked perfectly! Thank you!!
Of course!
If you don’t mind me asking, what setup do you have going! A 2070 mobile is not something you see everyday. Unless you are running a gaming laptop with a lot of sodimm ram!
Thats actually exactly what I have haha!
I had a Dell G7 7590 laying around that really doesn’t get used for much, I put a 32gb stick of ram in it and started playing around with Virtual machines. Mostly for stuff like Home Assistant and a file server. But I saw Wendell’s video on vGPU on Intel and it got me thinking about doing GPU Passthrough since this laptop has a 2070 in it that is just sitting there. My main computer is a MacBook Pro M1 so there are quite a few games that don’t run well or at all even with the game porting toolkit Apple has introduced. This seemed like a perfect fix for that since I really detest to running a windows machine as my daily driver. I was using a KVM Switch for a while but the new MacBooks don’t really work super well with the switch I had. This has got me wanting to build a full dedicated VM Server properly!
