Proxmox boot drive and USB DOMs
Howdy!
I’m working on a small form factor homelab build at the moment, and seeing conflicting and potentially outdated advice, so thought I’d consult some experts. :smile:
Specifically, I’m looking to run Proxmox on my server, which I’m designing primarily for compute (may expand into a NAS in the future, but I don’t have high needs). Currently, the entirety of my storage for this server is a single m.2 drive, a Crucial P3 Plus 1TB.
From what I’ve seen, Proxmox is potentially high-write on the boot drive due to status files and logs, and I’m semi-concerned this may wear out the drive at a higher rate than I’d like. I don’t care hugely about redundancy (since that would really just affect availability, I don’t intend on having any data I really care about), but I also obviously don’t want to wear out hardware for fun.
Is it worth considering a USB DOM as the boot drive instead, or is this a non-issue?
Additionally, in the year 2024, are USB DOMs still a common thing? I’ve seen various suggestions of using USB to m.2 adapters instead, as well as using either regular USB drives (such as the SanDisk Ultra Fit) or USB SSDs - DOM-wise, it seems like USB DOMs are less common than they once were (although I do see SATA DOMs). I’m pretty space (and port) constrained here though, so they may still be a good fit from that perspective.
New to all of this, so would appreciate advice! (My experience is all in the cloud where we never have to worry about hardware :wink:)
I don’t think I’m an expert but I’ve run two proxmoxes (one of them is still running) as a “hobby” (personal and not so personal dev/experiment machine) and both of them didn’t kill any drives in the span of 2+ years.
I suspect that the writes are nothing that would exceed average desktop usage.
Screenshot from “drives” section of my proxmox (all drives in it are second hand):
Thanks, great to know!
(Coincidentally, someone opened a thread on almost the same thing on STH at the same time as me, if anyone wants to check that out!)
I’m tempted to try a USB DOM or similar just for the fun of it anyway, if I can source something sensible.
