Proxmox 6.2 GPU Passthrough Issue
I was able to passthrough a FirePro W2100 to a VM on Proxmox 5.4 but after upgrading to proxmox 6.2, I am getting the fallowing issue from the host when the VM boots. Any help would be greatly appreciated.
[  112.621317] vfio-pci 0000:82:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=none
[  112.658288] vfio-pci 0000:82:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=none
[  112.658440] vfio-pci 0000:82:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=none
[  115.602098] vfio-pci 0000:82:00.0: enabling device (0000 -> 0003)
[  115.602310] vfio-pci 0000:82:00.0: vfio_ecap_init: hiding ecap 0x19@0x270
[  117.731424] vfio-pci 0000:82:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=none
What does your grub file look like?
nano /etc/default/grub
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR="Proxmox Virtual Environment"
GRUB_CMDLINE_LINUX_DEFAULT="quiet intel_iommu=on iommu=pt"
GRUB_CMDLINE_LINUX=""
# Disable os-prober, it might add menu entries for each guest
GRUB_DISABLE_OS_PROBER=true
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Disable generation of recovery mode menu entries
GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
Okay fair enough…
Should have asked initially, but what is the rest of the hardware in the system?
Also what’s in your /etc/modprobe.d/vfio.conf
Its an Intel(R) Xeon(R) CPU E5-2667 v2 @ 3.30GHz (2 Sockets) and i have an LSI HBA card installed. I have played around with other video cards and still having the same issue. The only thing that i can remember changing is the OS. I don’t believe that i changed the BIOS any from when it was working before the Proxmox upgraded.
options vfio-pci ids=1002:6608,1002:aab0
