Can sombody explain why this happening and how to fix it so that the data sent to stdin behaves the same way as the data typed in to stdin.
If you look at the /proc/$pid/fd, it is a sym link to a pts device:
$ ls -l /proc/1703/fd/
total 0
dr-x------ 2 chris users 0 Aug 14 17:03 ./
dr-xr-xr-x 9 chris users 0 Aug 14 17:03 ../
lrwx------ 1 chris users 64 Aug 14 17:03 0 -> /dev/pts/2
lrwx------ 1 chris users 64 Aug 14 17:04 1 -> /dev/pts/2
lrwx------ 1 chris users 64 Aug 14 17:03 2 -> /dev/pts/2
lrwx------ 1 chris users 64 Aug 14 17:04 4 -> socket:[44154435]
What you are doing is the same as writing to the pts:
$ echo hello > /dev/pts/2
There must be a way to make chars available for reading on the pts, as that is what the terminal window is doing when you type into it. It may involve hacking the terminal code, Iām not sure.
Yeah i just fucking gave up because it was not worth it. Instead i just wrote a python script.
import socket
from os import system
from sys import platform as _platform
def clear():
if _platform == "linux" or _platform == "linux2" or _platform == "darwin":
system("clear")
elif _platform == "win32" or _platform == "win64":
system("cls")
return
ip = "127.0.0.1"
port = 4005
lenBuffer = 1024
commands = {"new" : "\x30\x02\x00\x00\x00\x00\x00\x00\x00\x01\x00\x00\x00\x00\x00\x00\x00\x05\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x6c\x6f\x6c",
"select" : "\x20\x6c\x6f\x6c",
"flush" : "\x40"}
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
try:
s.connect((ip, port))
except ConnectionRefusedError:
print("[ERROR] Server is not online.")
else:
print("SaturnDB Interactive Testing Tool")
while True:
command = input(">> ")
if(command in commands):
s.send(bytes(commands[command], "utf-8"))
elif command == "q" or command == "exit":
break
elif command == "clear":
clear()
else:
print("[ERROR] Command does not exist.")
s.close()
This might be job for tmux:
$ tmux new -s myterm
In another terminal:
$ tmux send-keys -t myterm "ls" ENTER
The ālsā command is sent to the tmux session āmytermā and executed in the bash shell.
Yeah so actually made a Unix stack exchange things aswell: https://unix.stackexchange.com/questions/462630/proc-stdin-weird-behaviour
But your solution is better though can you send hexadecimal data? Because that was the whole purpose of this thing.
By hexadecimal I mean binary but escaped with hex like 0x0A
All I know about it is through the man page. Iād have to dig deeper than that to determine what kind stuff you can do.
Can you explain what the problem is here? It looks like itās doing what it should be to meā¦
Oh I should have read the stackexchange post, you were expecting the echoed text to show up in the netcat server terminal. Yep the characters you type are echoed by the terminal, not netcat.
Yupā¦
nwshell isnāt reachable yetā¦
$ traceroute nwshell.com
5 te0-6-0-4.rcr21.b003070-1.sfo01.atlas.cogentco.com (38.88.216.117) 3.482 ms 3.484 ms 3.478 ms
6 be2682.ccr22.sfo01.atlas.cogentco.com (154.54.6.169) 3.468 ms be2681.ccr21.sfo01.atlas.cogentco.com (154.54.5.233) 3.121 ms be2682.ccr22.sfo01.atlas.cogentco.com (154.54.6.169) 3.115 ms
7 be2016.ccr31.sjc04.atlas.cogentco.com (154.54.0.178) 3.126 ms 3.044 ms 2.909 ms
8 palo-b1-link.telia.net (62.115.34.73) 2.865 ms 2.860 ms 2.834 ms
9 nyk-bb3-link.telia.net (62.115.114.4) 99.324 ms nyk-bb4-link.telia.net (62.115.122.37) 89.123 ms nyk-bb3-link.telia.net (62.115.114.4) 94.681 ms
10 nyk-b5-link.telia.net (80.91.254.14) 72.154 ms ash-bb3-link.telia.net (62.115.141.244) 90.093 ms 90.104 ms
11 cha-b1-link.telia.net (80.91.252.101) 84.403 ms 84.397 ms 84.372 ms
12 giglinx-ic-156088-cha-b1.c.telia.net (213.248.68.138) 101.506 ms 101.503 ms 100.835 ms
13 * * *
14 * * *
15 ashv1.main-hosting.com (208.69.231.10) 83.618 ms 83.480 ms 83.583 ms
16 * * giglinx-ic-156088-cha-b1.c.telia.net (213.248.68.138) 103.501 ms
17 * * *
18 * * *
19 * ashv1.main-hosting.com (208.69.231.10) 80.672 ms *
20 * * *
Thatās fucking weird it works for me on chrome. Maybe some of the DNS servers need to update.
It resolves to 31.170.160.61 on my side.
Country?
Iām in California.
thatās maybe it
they maybe updated the european servers first instead
Iāll try laterā¦
Link works now!
A use for this would be an interactive binary protocol?
