Hello,
I have a serious problem with this USB-C dock:
https://i-tec.cz/en/produkt/c31minidock4kpd-2/
Actually two problems.
First is that the USB-A ports (I can’t really test that type-C port since I don’t have anything that uses USB-C besides my laptop [Thinkpad E580] and its charger), ethernet, power delivery and HDMI are working fine. Log from dmesg:
[ 1136.239017] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 1136.352850] usb 2-2: New USB device found, idVendor=2109, idProduct=0813, bcdDevice=90.11
[ 1136.352858] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1136.352862] usb 2-2: Product: USB3.0 Hub
[ 1136.352866] usb 2-2: Manufacturer: VIA Labs, Inc.
[ 1136.356023] hub 2-2:1.0: USB hub found
[ 1136.356216] hub 2-2:1.0: 4 ports detected
[ 1136.517542] usb 1-2: new high-speed USB device number 13 using xhci_hcd
[ 1136.677515] usb 1-2: device descriptor read/64, error -71
[ 1136.947575] usb 1-2: device descriptor read/64, error -71
[ 1137.067606] usb usb1-port2: attempt power cycle
[ 1137.209143] usb 2-2.4: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 1137.332913] usb 2-2.4: New USB device found, idVendor=2109, idProduct=0813, bcdDevice=90.11
[ 1137.332919] usb 2-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1137.332922] usb 2-2.4: Product: USB3.0 Hub
[ 1137.332925] usb 2-2.4: Manufacturer: VIA Labs, Inc.
[ 1137.336503] hub 2-2.4:1.0: USB hub found
[ 1137.336710] hub 2-2.4:1.0: 4 ports detected
[ 1137.777581] usb 1-2: new high-speed USB device number 14 using xhci_hcd
[ 1137.777697] usb 1-2: Device not responding to setup address.
[ 1138.007665] usb 1-2: Device not responding to setup address.
[ 1138.227533] usb 1-2: device not accepting address 14, error -71
[ 1138.327584] usb 2-2.4.4: new SuperSpeed Gen 1 USB device number 4 using xhci_hcd
[ 1138.358581] usb 2-2.4.4: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=31.00
[ 1138.358586] usb 2-2.4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 1138.358589] usb 2-2.4.4: Product: USB 10/100/1000 LAN
[ 1138.358592] usb 2-2.4.4: Manufacturer: CMI
[ 1138.358594] usb 2-2.4.4: SerialNumber: 001000001
[ 1138.517556] usb 1-2: new high-speed USB device number 15 using xhci_hcd
[ 1138.517681] usb 1-2: Device not responding to setup address.
[ 1138.747601] usb 1-2: Device not responding to setup address.
[ 1138.967534] usb 1-2: device not accepting address 15, error -71
[ 1138.967627] usb usb1-port2: unable to enumerate USB device
[ 1139.031649] usbcore: registered new interface driver r8152
[ 1139.042434] usbcore: registered new interface driver cdc_ether
[ 1139.137880] usb 2-2.4.4: reset SuperSpeed Gen 1 USB device number 4 using xhci_hcd
[ 1139.219157] r8152 2-2.4.4:1.0 eth0: v1.09.9
Second problem is much less obvious, after using this dock for a few minutes fan in mentioned laptop started ramping up, turns out ksoftirqd was using 100% of one core and some proceses became unresponsive.
/proc/interrupts
CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
0: 8 0 0 0 0 0 0 0 IR-IO-APIC 2-edge timer
1: 0 0 17 0 0 0 0 0 IR-IO-APIC 1-edge i8042
8: 0 0 0 0 0 0 0 1 IR-IO-APIC 8-edge rtc0
9: 0 8094 0 0 0 0 0 0 IR-IO-APIC 9-fasteoi acpi
12: 0 188 0 0 0 0 0 0 IR-IO-APIC 12-edge i8042
16: 0 0 0 0 0 0 0 206 IR-IO-APIC 16-fasteoi i801_smbus
120: 0 0 0 0 0 0 0 0 DMAR-MSI 0-edge dmar0
121: 0 0 0 0 0 0 0 0 DMAR-MSI 1-edge dmar1
122: 0 0 0 0 0 0 0 0 IR-PCI-MSI 458752-edge PCIe PME, pciehp
123: 0 0 0 0 0 0 0 0 IR-PCI-MSI 466944-edge PCIe PME, aerdrv
124: 0 0 0 0 0 0 0 0 IR-PCI-MSI 475136-edge PCIe PME, aerdrv
125: 0 0 0 0 0 0 0 0 IR-PCI-MSI 479232-edge PCIe PME, aerdrv
126: 0 0 0 0 0 0 0 0 IR-PCI-MSI 481280-edge PCIe PME, aerdrv
127: 0 0 0 0 0 0 0 23 IR-PCI-MSI 2097152-edge nvme0q0
128: 15207 0 0 0 0 0 0 0 IR-PCI-MSI 2097153-edge nvme0q1
129: 0 16848 0 0 0 0 0 0 IR-PCI-MSI 2097154-edge nvme0q2
130: 0 0 15587 0 0 0 0 0 IR-PCI-MSI 2097155-edge nvme0q3
131: 0 0 0 14915 0 0 0 0 IR-PCI-MSI 2097156-edge nvme0q4
132: 0 0 0 0 16999 0 0 0 IR-PCI-MSI 2097157-edge nvme0q5
133: 0 0 0 0 0 20457 0 0 IR-PCI-MSI 2097158-edge nvme0q6
134: 0 0 0 0 0 0 15836 0 IR-PCI-MSI 2097159-edge nvme0q7
135: 0 0 0 0 0 0 0 17443 IR-PCI-MSI 2097160-edge nvme0q8
136: 0 0 0 4910695 0 0 0 0 IR-PCI-MSI 327680-edge xhci_hcd
137: 0 0 0 0 0 0 0 0 IR-PCI-MSI 3145728-edge mmc0
138: 0 0 0 0 0 0 0 0 IR-PCI-MSI 376832-edge ahci[0000:00:17.0]
139: 0 0 0 0 0 0 39 0 IR-PCI-MSI 360448-edge mei_me
140: 0 0 0 0 0 0 0 0 IR-PCI-MSI 1572864-edge enp3s0
141: 0 1736570 0 0 0 0 0 0 IR-PCI-MSI 32768-edge i915
142: 0 0 37625 0 0 0 0 0 IR-PCI-MSI 2621440-edge r8822be
143: 0 0 0 0 0 0 0 16 dummy 44 rmi4_smbus
144: 0 0 0 0 0 0 0 0 rmi4 0 rmi4-00.fn34
145: 0 0 0 0 0 0 0 0 rmi4 1 rmi4-00.fn01
146: 0 0 0 0 0 0 16 0 rmi4 2 rmi4-00.fn03
147: 0 0 0 0 0 0 0 0 rmi4 3 rmi4-00.fn11
148: 0 0 0 0 0 0 0 0 rmi4 4 rmi4-00.fn11
149: 0 0 0 0 0 0 0 0 rmi4 5 rmi4-00.fn30
150: 0 0 0 587 0 0 0 0 IR-PCI-MSI 514048-edge snd_hda_intel:card0
NMI: 0 0 0 0 0 0 0 0 Non-maskable interrupts
LOC: 513087 734789 515662 532569 520357 495818 527954 521802 Local timer interrupts
SPU: 0 0 0 0 0 0 0 0 Spurious interrupts
PMI: 0 0 0 0 0 0 0 0 Performance monitoring interrupts
IWI: 9 87271 16 17 65 10 11 11 IRQ work interrupts
RTR: 0 0 0 0 0 0 0 0 APIC ICR read retries
RES: 78649 78742 54895 70677 73676 33334 34711 31229 Rescheduling interrupts
CAL: 95216 62115 91503 79876 57095 65125 68973 72245 Function call interrupts
TLB: 24745 25333 25816 29211 23285 22411 20816 34383 TLB shootdowns
TRM: 0 0 0 0 0 0 0 0 Thermal event interrupts
THR: 0 0 0 0 0 0 0 0 Threshold APIC interrupts
DFR: 0 0 0 0 0 0 0 0 Deferred Error APIC interrupts
MCE: 0 0 0 0 0 0 0 0 Machine check exceptions
MCP: 11 12 12 12 12 12 12 12 Machine check polls
HYP: 0 0 0 0 0 0 0 0 Hypervisor callback interrupts
HRE: 0 0 0 0 0 0 0 0 Hyper-V reenlightenment interrupts
HVS: 0 0 0 0 0 0 0 0 Hyper-V stimer0 interrupts
ERR: 0
MIS: 0
PIN: 0 0 0 0 0 0 0 0 Posted-interrupt notification event
NPI: 0 0 0 0 0 0 0 0 Nested posted-interrupt event
PIW: 0 0 0 0 0 0 0 0 Posted-interrupt wakeup event
Number in this line:
was going up pretty fast, I also wasn’t able to shut down the system even after unplugging this dock.
OS: ArchLinux
Kernel: 4.19.86-1-lts [on the non-lts the problems were the same]
