Digging in the log (found the commands via applealc homepage) i get this
Filtering the log data using "process == "kernel" AND (composedMessage CONTAINS "AppleALC" OR composedMessage CONTAINS "Lilu")"
Skipping info and debug messages, pass --info and/or --debug to include.
Timestamp (process)[PID]
2020-12-30 06:16:04.541523-0800 localhost kernel[0]: calling mpo_policy_init for Lilu
2020-12-30 06:16:04.554159-0800 localhost kernel[0]: Security policy loaded: Lilu Kernel Extension 1.4.9 (Lilu)
2020-12-30 06:16:08.654054-0800 localhost kernel[0]: (Lilu) AppleALC alc: @ error: no layout-id property found in configuration
2020-12-30 06:16:45.452232-0800 localhost kernel[0]: (Lilu) AppleALC alc: @ failed to obtain device info for analog controller (1)
2020-12-30 06:34:52.599146-0800 localhost kernel[0]: calling mpo_policy_init for Lilu
2020-12-30 06:34:52.611741-0800 localhost kernel[0]: Security policy loaded: Lilu Kernel Extension 1.4.9 (Lilu)
2020-12-30 06:34:56.111126-0800 localhost kernel[0]: (Lilu) AppleALC alc: @ error: no layout-id property found in configuration
2020-12-30 06:35:02.454734-0800 localhost kernel[0]: (Lilu) AppleALC alc: @ failed to obtain device info for analog controller (1)
2020-12-30 15:06:52.907818+0000 localhost kernel[0]: (Lilu) AppleALC alc: @ error: no layout-id property found in configuration
2020-12-30 15:06:52.907918+0000 localhost kernel[0]: (Lilu) Lilu user: @ disabling user patcher on request!
2020-12-30 15:07:04.459803+0000 localhost kernel[0]: (Lilu) AppleALC alc: @ failed to obtain device info for analog controller (1)
2020-12-30 07:08:52.979305-0800 localhost kernel[0]: (Lilu) AppleALC alc: @ error: no layout-id property found in configuration
2020-12-30 07:08:52.979894-0800 localhost kernel[0]: (Lilu) Lilu user: @ disabling user patcher on request!
2020-12-30 07:09:05.459027-0800 localhost kernel[0]: (Lilu) AppleALC alc: @ failed to obtain device info for analog controller (1)
2021-01-01 07:16:01.887586-0800 localhost kernel[0]: (Lilu) AppleALC alc: @ error: no layout-id property found in configuration
2021-01-01 07:16:01.887714-0800 localhost kernel[0]: (Lilu) Lilu user: @ disabling user patcher on request!
2021-01-01 07:16:12.105642-0800 localhost kernel[0]: (Lilu) AppleALC alc: @ failed to obtain device info for analog controller (1)
2021-01-01 07:29:24.749125-0800 localhost kernel[0]: (Lilu) Lilu user: @ disabling user patcher on request!
2021-01-01 07:31:18.822476-0800 localhost kernel[0]: (Lilu) Lilu user: @ disabling user patcher on request!
2021-01-01 07:33:58.572545-0800 localhost kernel[0]: (Lilu) Lilu user: @ disabling user patcher on request!
2021-01-04 17:27:43.021806+0100 localhost kernel[0]: (Lilu) AppleALC alc: @ error: no layout-id property found in configuration
2021-01-04 17:27:43.022600+0100 localhost kernel[0]: (Lilu) Lilu user: @ disabling user patcher on request!
so i gues i need some kind of layout id, any suggestions on how to get that setup correctly ?
i tried mounting the efi folder and adding alcid=11 to boot arguments. Now the virtual machine cannot start. I will have to figure out how to mount the efi partition from within ubuntu somehow
ok so i managed to reset the EFI via redownloading the osx-kvm repos and just reploace my xml configs and disks and base system and osx can now boot again.
I cannot figureout if it was the alcid=11 that prevneted the boot.
