Problem with Arctic Liquid Freezer III
Hi guys, I bought an Arctic Liquid Freezer III 360, but it’s very loud. The problem is that, both in BIOS and in Fan Xpert, I see that it’s always running at 3000 RPM. Even if I try to change the fan curve from either interface, the speed stays fixed at 3000 RPM.
I have connected all three cables correctly:
Fan to CPU_FAN
VRM to CPU_OPT
Pump to AIO_PUMP
You don’t mention what you have tried to address the issue, so here are some suggestions:
So you’ve checked the cables are correct. The next stage is to confirm the BIOS is set to control the fans. Mine are set to PWM for the type - I’m not sure if “auto” worked on mine so that is worth a try. Then check the CPU temperature displayed - as the fans are flat out it should be fairly cool. My AMD CPU shows 45C/113F at about 900RPM. If your CPU is much hotter then it may be you need to redo the cooler. Then check the fan profile - if you set it to max at a low CPU temperature then it will run fast and loud.
See how that goes first…and good luck
I remember there were two cables included. One with just power, other with 3 cables (power, fan, usb). I assume you are using the second one. Try the first to see if the sound is exactly the same(I’m assuming that maybe you have a faulty cable… or just put the pump as the highest point).
Hi, i tryed to put the PWM and i also tryed to put the fan at 0% but nothing changed the fans are still at 3000 RPM
