Never mind FIXED IT
**fsstab contained wrong UUID in entry that i did not add there so i did not think about it as a problem whoopz dumb meatbag.
MOD CAN DELETE THIS
This error comes when i try mount this using fstab if i remove mount from fstab system does not enter into emergency shell. But this setup worked all ok until i accidentally booted pfSense in this machine and it saw LVM disks. I dont what usefull info to offer more. This all comes after PV Scan … and then dev-disk starts… this is not main os LV/VG
[root@mainframe ~]# journalctl -b -1 | grep x2d8eed098f9757
Jan 11 17:22:45 mainframe systemd[1]: dev-disk-by\x2duuid-735ef3d5\x2d4ea8\x2d4086\x2db439\x2d8eed098f9757.device: Job dev-disk-by\x2duuid-735ef3d5\x2d4ea8\x2d4086\x2db439\x2d8eed098f9757.device/start timed out.
Jan 11 17:22:45 mainframe systemd[1]: Timed out waiting for device dev-disk-by\x2duuid-735ef3d5\x2d4ea8\x2d4086\x2db439\x2d8eed098f9757.device.
Jan 11 17:22:45 mainframe systemd[1]: dev-disk-by\x2duuid-735ef3d5\x2d4ea8\x2d4086\x2db439\x2d8eed098f9757.device: Job dev-disk-by\x2duuid-735ef3d5\x2d4ea8\x2d4086\x2db439\x2d8eed098f9757.device/start failed with result 'timeout'.
