Printer (laser) scanner or combo (cheap) (linux compatible)
Ahoy like-minded fellow poor people,
I seek for cheap laser printer combo with cheap cartridges for occasional printing of drawings/schematics and scanning of machine manuals any advice is appreciated.
(bonus point is if works out of box on linux) :slight_smile:
Roommate has a Cannon MX492. Second cheapest model at the time (cheapest doesn’t work at all). It’s a PITA to set up but it works. Probably discontinued now.
I’m not sure if your title means a Laser printer OR combo (ink)… Last laser I had was an HP like 20 years ago, not a combo, wasn’t cheap heh.
well there is one new here in online-store localy, but ~150$ isn’t kinda cheap :S
Lasers aren’t typically cheap and a lot of manufactures have been trying to discontinue them.
Laser MFPs will be expensive if you can’t find one used in general, as long as it supports PCL5/6 and/or Postscript you’ll be fine as far as printing goes. For scanning you might need to setup a local ftp server because the firmware wont support newer variants of the SMB protocol using Samba or ksmbd.
hmm why would i need a network connected one? :open_mouth:
Good luck finding one without wired or wifi need or no. :wink:
Because non networked ones are usually host based which will only give you trouble and are built to a cost. Also, are you going to run back and forth with a USB stick (given that you’re going for a MFP).
mhm I haven’t thought about it, haven’t had printer since 2007, and in that time i had lexmark chepo inkjet, so I was curious if “recent” ones are as trash as that one was, also i rarely print so it needs to be laser, otherwise 1 cartridge for 1 print ain’t smart :S.
also 0 experience with printers/scanners on linux (i imagine it works like bluetooth (plug-and-play)) or maybe not ?
Plug in the USB cable or connect over wifi these days. Printers were trash, now only worse…predatory practices and lockins are rampant.
how is driver support, would i need to passthrou usb controler and use windows wm to use it? :slight_smile: usb
As said earlier, get one that supports PCL5/6 and/or Postscript
Next is for you to do some research
As @diizzy said.
I haven’t kept up with CUPS since Apple ditched it so…
ill try to browse local old-pc stores and see what types they have, if there is still buy-able cartridges for em, then ill look for compatibility
The ink carts will likely be easy to find. Most the industry has tried to kill laser because they last and are typically pretty cost effective once you get past the initial purchase. Which means they want you to use the piggish break down suck your wallet to death ink cart models…so there is still ample support for them and carts a plenty for new and old.
Frankly I’ve always been against combo’s. One thing breaks you have to buy an individual unit anyhow to replace it. Or a whole new unit, either way eWaste in the making…but that’s how they like it.
The best thing to do is just buy something cheap at like a wally, bring it home, try to install. If it’s a no go take it back and get the slightly more expensive model…rinse and repeat until you have it. That’s what we did last time. Went to wally, grabbed the cheapest POS and tried it out. No dice, took it back, got the one that was $5 more…good to go.
It was better when CrapCo did in refills but we print so little carts last a long time.
What are you talking about? Almost everyone except home users use lasers if they print any decent amount.
In deed, I even forgot about the “planned obsolescence”
Yeah on leased machines…that office equipment is not for sale or a few thousand up front. If you see a lucky receptionist with a nice laser at her desk it’s likely old…or on lease.
By the way, as I see you’re the man of knowledge about office stuff, do you know any way to translate pdf manuals on spot (like using google lense) without loosing position of text or similar way?
So you wanna say that there exist “Rent-a-printer”? like Rent-a-car type of thing?
