Just got done with some cable management, im going yo be getting 2 GTX 680s soon so Im just preping for them. Tell me if you like my cable management, or what needs improvement?
BACK
before:
After:
INSIDE
Before:
After:
Is this good cable management and is it more orderly than the previous pics? What are your opinions on my setup and dual sli 680s that I want to get?
Well its certainly better then the before photo. A set of sleeved extensions (pcie, 24pin, 8pin etc) would work wonders. Good that you'll have fans blowing directly on the gpu's, when you get them anyways. Cable management can take a lot of time to get it right but it worth it in the end I reckon.
