KVM Model:
Not yet purchased — looking for advice before buying
Not yet decided — open to either
Problem:
I’m trying to find out if the L1T DP 1.4 KVM will work with my specific setup before buying. My monitor is an LG 34WK95U-W (5120×2160@60Hz via DP 1.4, HDR) which is an unusual VESA timing. My key question is whether the KVM passes the DisplayPort signal transparently (pure mux) or whether there is an active chip in the signal path that needs to recognise the resolution — because if it’s the latter, 5120×2160 may not be in its lookup table.
Other Notes:
Peripherals that need to work fully (not just basic HID):
Corsair K100 Air Wireless RGB (I noticed Corsair is listed as problematic with hotkeys — is there a workaround?)
Logitech MX Master 4
3DConnexion SpaceMouse Enterprise
Elgato Stream Deck XL
Switching between Windows 11 and Manjaro Linux. Has anyone run this monitor or any other 5120×2160 panel with an L1T KVM successfully?
