Power user Steam Frame Discussion
Wanted to start a thread to discuss Steam Frame power user and hacking tips and tricks, as well as a thread for people to post what they’ve learned about this hardware.
I’ll start. My Steam Frame is my personal laptop replacement at this point. I have a folding bluetooth keyboard and usb dongle that allows me to use the desktop interface like I would a laptop, but with a massive screen and with full color passthrough thanks to the camera addon. In order to get my actual working environments setup I set up the nix package manager on the steam frame and used some systemd mounting schenanigans to get the /nix directory to work correctly. With the nix package manager I was able to get distrobox installed, and get a fedora distrobox up and running. In that box I’ve installed my code editor, rust libraries, hermes agentic harness, and some hacking tools like burpsuite, nmap, netexec, etc. Its a fantastic little computer for what I’m using it for (mostly CTFs and coding my offensive tooling).
Some questions I have that I’m not sure how to answer, maybe you guys can help!
  1. The expansion port on the front of the device that my camera module is plugged into IIRC is just a PCIE interface. Does it support bifurcation? how can I tell?
  2. setting up systemd –user services doesn’t seem to work, I don’t have the exact error message handy, but was wondering if anyone else has figured this one out already?
  3. Fedora is fine in my distrobox, but my perferred environment is Arch, is there an Arch image I can use that works with the ARM processor?
  4. I haven’t tried setting up QEMU/KVM yet, but if anyone has I’d be curious to know what issues you ran into and how you attempted to solve those.
Overall, I’m extremely happy with this device, it plays games great, streams from my cachyos system great (after some troubleshooting and setup), and I get to code and hack things from a linux computer on my face which feels so cyberpunk.
Anyone else have cool things they’ve setup, are working on, or want me to try on my steamframe to see if it works?
I have the steam frame too, I’ve been away from home for a couple of weeks, but will be back in a couple of days, and was going to try and set it up for software development as well, especially to try compiling on arm. Why are you using distrobox instead of running your tools directly on steamOS? Its arch based. There does exist https://archlinuxarm.org/ but as far as I understand its not at all as functional as x86 arch. I’m not 100% sure but your issue with systemd might be caused by steamOS being immutable, from some quick googling other people seem to have issues with configuring systemd on immutable distros. As for the camera port, it is pcie4 but it is only X1 meaning you only have one lane, so there arent any lanes to split. it does also have 8 lanes of MIPI though, and those can apparently be divided across several different devices, like cameras. I have very little knowledge of MIPI though, so I cant answer any questions about that.
As for my questions:
  • Are you using frametop? I haven’t tried it yet, but it seems awesome for doing development work on
  • How are you handling the relatively low resolution when coding, is it distracting, and are you using a larger font size to compensate for it?
I suppose I could get my dev environment running on SteamOS directly instead of using a distrobox. The main reason I didn’t was two fold:
  1. SteamOS being an immutable atomic distro means that if you unlock the readonly root file system and use pacman to install things, those changes will lost after SteamOS updates. You could do some overlay filesystem hackery to make it work better, but due to the nature of SteamOS it means you’ll always have a partially upgraded arch system, which is not ideal.
  2. not everything I want to use is available as a flatpak in the steam frame discover store, zed for example. So setting up my full dev environment in a distrobox where those packages are available via the standard package manager is the better solution. For fedora I did run the ultramarine conversion script so that I get all the extra repos and nice to have softwares that come along with it.
My hacking environment (for pentests and CTFs) is, and always was going to be a distrobox though. I’m a pentester by trade (hopefully senior pentester come January), and the distrobox setup matches my work laptop’s hacking environment setup. Using distrobox allows me to keep a “template” distrobox with all my tools and default configurations set up, then for each engagement or project I clone that into a project specific distrobox. This keeps all the attack tooling databases separate from eachother, and if I need to do some funky config changes to make attacks work it doesn’t effect the host OS, or any other project setup, only the one that needs it. Since I was already going to be setting up distrobox for that I figured might as well set one up for dev work too.
I have used archlinuxarm on my pixel phone’s pkvm debian machine in a distrobox before, but found the availability of packages to be severely lacking compared to normal Arch, plus any standard AUR packages that ship as binaries instead of source code won’t run since they’re going to be packaged as x86_64 binaries not Arm64. I haven’t tried out any other arch based distros that ship on Arm yet though, I know there’s a few besides ALARM, but again haven’t tested them yet.
I have seen frametop, and attempted to set it up once, but it didn’t work for me so I uninstalled it. Might try again and try to troubleshoot it a bit more to see if I can get it running. Funnily enough I think frametop basically just sets up a distrobox of Fedora linux with KDE and launches it with multiple virtual montiors set up. For now I just use the one desktop window with multiple virtual desktops that I switch between using keyboard shortcuts.
I have used framemouse though which is interesting, basically if you’re sitting at a table or desk you can launch desktop mode with a bluetooth keyboard, start the framemouse script then place the controller on the table and press the A button, the controller then acts like a desktop mouse, with the shoulder button being left click and the trigger being right click, if you lift the controller up it stops tracking just like a desktop mouse too, its… interesting… not sure if I like it as much as a desktop mouse, but again its certainly interesting… one weird bug I have with it though is ever since I installed it, when I launch desktopmode the cursor is HUGE, going into the kde settings and changing the cursor size fixes it, but the fix doesn’t persist to the next launch of Desktop.
I did get around to playing with frametop. It’s super cool, a bit janky as of yet, but works well enough. I might factory reset my frame and set it up with frametop in mind first then get all my custom stuff implemented in frametop. It works pretty well though.
