I am beginning to investigate possible builds for a “Pass-through” system and I was wondering the following:
Say we have the following:
- Host with integrated GPU
- Host with integrated GPU + an non-initialized dedicated GPU
- Host with integrated GPU + initialized GPU
Supposedly once your launch VM the drivers/utilities should do power managed on the dedicated GPU, which makes sense.
- Gives the lowest power usage(duh all is integrated)
- “Should” result in power consumption couple of wats above option 1.
- “Should” result in power consumption option 1 + power consumption of the GPU
I am asking, since I have a Maxwell based chip with power unlock which is great and I want to keep it until there is a proper mainstream GPU that can handle 4k(from AMD that is).
P.S. - Of course running a VM will eat some more CPU and RAM power, but that should be negligible, compared to 400W GPU.
