Ok so i just set up my computer today and it wont start, i used the paper clip test on the PSU and it works. But when i plug the PSU into the mobo, nothing...
Is there a way to check my mobo or cpu to be dead?
The other thing is i think the bracket for the H60 might be touching metal on the back, would that short it out and cause it do to nothing?
Heres mainly what i got
CASE http://www.newegg.com/Product/Product.aspx?Item=N82E16811345016
PSU http://www.newegg.com/Product/Product.aspx?Item=N82E16817139051
MOBO http://www.newegg.com/Product/Product.aspx?Item=N82E16813130738
CPU http://www.newegg.com/Product/Product.aspx?Item=N82E16819116900
Cooler http://www.newegg.com/Product/Product.aspx?Item=N82E16835181030
