Posting Problem
so on my newest build which is a re-puttogether of parts (i got an new processor and put it into a old(working) motherboard with some new memory) i have finally finished building it but im having a problem with posting.  when i turn the computer on the onboard speaker beeps 5 times and the fans and whatnot startup but no splash screen or bios or anything comes up.  But there is just  a black backlit picture on my monitor (because it auto tunrs off i there is no picture).
Thanks in advance
(this is similar to one of my other posts but its a new problem)
You should check your motherboard's documentation to find out what the 5 beep POST code means, then start there. Also, some more info about your setup would help the rest of us tell you what to try to fix it.
