Hi, Apologies if this is the wrong category, I just need some guidance from some postgres wizards.
I’m getting the following when interacting with a database (name obfuscated, but it does have the - in it)
WARNING: database "database-name" has a collation version mismatch
DETAIL: The database was created using collation version 2.38, but the operating system provides version 2.40.
HINT: Rebuild all objects in this database that use the default collation and run ALTER DATABASE "database-name" REFRESH COLLATION VERSION, or build PostgreSQL with the right library version.
As far as I can find online, the command it tells me to run is the correct one and should be working, but I get
ALTER DATABASE "database-name" REFRESH COLLATION VERSION;
ERROR: syntax error at or near "REFRESH"
LINE 1: ALTER DATABASE "database-name" REFRESH COLLATION VERSION;
Anyone able to tell me what I’m doing wrong? I’m able to check the collation version and that comes back as up to date
postgres=# ALTER COLLATION "en_GB.utf8" REFRESH VERSION;
NOTICE: version has not changed
ALTER COLLATION
