Friends were over getting ready to start a board game so I rushed my 7v fan project.
(for people who do not know a 7v mod is where you take a 4-pin molex and swap the gnd and 5v lines so a 12v fan runs at 7v and quieter. Something we did before PWM fans or decent fan controlloers).
My fan mod worked, but I put the end of the molex chain into the hard drive. Grey smoke instantly billowed out that back fans as the hard drive must have drawn close to double the amps and melted the wiring housing. I turned it off fast but it sure made me look like an idiot in front of everybody.
The PSU actually still worked fine except for the melted wires obviously. Drive was ok too. But it smelled awful!
I just threw up on my das keyboard (two months old or so) and it is not working anymore. FUCKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKing shit… I took it apart wiped it down with rubbing alcohol. Hopefully it will be fine after a day or two of no use. God fucking dammit!!!
My work moved into a new office and I was setting up the new network closet. I couldn’t figure out why all the VOIP phones couldn’t connect to the internet.
So I check the signal from the closet to the wall, double-check the demarc, check to so if the APs have internet. I then realized I forgot to uplink from the phones switch to the main switch (there are only 2 switches in the closet). I was too focused on making sure all the cabling was neat and tidy in my new network closet.
Had an LG G3 flashed with lineageOS. Installed an app that claimed to lower the 4k to 1080p and make the phone snappier. Hard bricked the phone so bad had to send it to a guy on ebay that could factory flash it with a jtag.
Was trying to flash tasmota on an esp board and didn’t know I was supposed to cross over tx and rx, was spoiled with wireless methods on other boards.
Sure I have plenty other fails I’ll remember if given time.
The fact that she personally drove a laptop 1400km instead of mailing it is far more of a fail than thinking it’s dead for plugging it into an inactive power source.
At work, someone had set the /etc/hosts file to be immutable on around 1/2 of the environment so when I went to update and reboot the primary DNS server we got flooded with dns resolution failed logs because I had pushed out a change to failover to the secondary DNS server first which ofc didn’t get through to everything.
Power related , not all tech but funny now time has passed.
Plugged a 3.5 floppy power connection one pin offset, clouds of pvc smoke / wire melting as I powered on the pc !
Was with engineer in work and we was showing our senior suit why important customer had a fault with his new system, holding up a mains powered board with a glass fuse at 240Volts (bare metal ends) we pointed it out as having been the problem, he then quick as a flash pushed his finger on the fuse, saying this one ? He did not visit engineering much again !!
Tried to ignite sparkler firework with a metal wire core on an electric bar heater when a small boy, yes still remember that even many many years later.
That oh no thump as new 3TB drive was pushed of the side of my table, the click of death was inevitable, not having much money at the time as well… all my own fault for getting careless.
reminded me of a fail of mine. I borrowed a cpu from a friend (8350), I left it on a tv dinner table pins not protected. Not paying attention I backed into that tv dinner table and all the pins went caput. All of them. I didn’t bother trying to put humpty dumpty back together. Luckily microcenter had a deal for a 8350 that went for like 50 dollars. Easy enough I bought that for him.
I couldn’t get my finger or a screwdrive between my gpu and the heatsink to unlatch the clip. So I pulled the gpu out without considering the damage. In hind site it wasn’t the end of the world. But the possibility of destroying my motherboard didn’t seem to bother me. It broke the clip. Now i have a gpu that easily comes out of the pcie slot. And the pcie slot still works.
When I was much younger a similar occurrence happened. I pulled out a sata cable with the clip not realizing there was a clip and broke the motherboard and it wouldn’t boot after that.
It is not DNS,
It is definitely not DNS,
It can’t be DNS,
It was DNS.
Phone was not working. Since my modem/router offers all the options, I almost randomly changed things around. At some point, changing SIP from UDP to TCP made it work…
Until I had to either restart my router or accidentally unplugged it. Phone dead, again.
Today I went through the entire configuration for the phone again, following the provided documentation and documentation for my ISPs enterprise service.
It was off course, DNS.
I was sweeping around desks, pulled a chair out and it cought a stack of HDDs on the edge of the desk, 5 of them tumbled to the ground, they’re customers…
