hi !
I just wanted to do a quick post in order for other to not replicate what i just did…
if you have a modular PSU, don’t plug your sata power blindly. I couldn’t see the pin so i wacked it at the PSU until it fit … it did fit … in the PCI connector >.<
12V in the 5v or 3.3v, the 2 intel ssh and my poor WD Velociraptor didn’t liked it Magic smoke everywhere…
Welp, that’s it i guess
Edit: i am buying a donor board for my Velociraptor, and i took a picture of the fried board for posterity
The platters would still be alright, no? If the drive had something vital, you could take it to a data recover place and they could attempt to swap the platters.
already asked for quote, the data is not vital but nice to have (my old windows is on it)
But i loved that thing, a blast for the past >< i need to find another one from ebay
Moral of the story - be careful where you stick your things people…
Sorry to hear that. I can relate to loving old tech, no matter almost all of mine is fairly modern. I think if you are lucky you may find great condition velocyraptors used…
Sadly no, on my corsair psu, the 6 pin fot the sata is keyed identically than the first 6 of the 8 pin pci only the label can help you, so it took no effort to plug in the wrong one
I’ve had “magic” smoke everywhere, but not because I did something wrong, well I did, but the thing is I did not check how much power computer would receive from my home. Little did I know, the el socket that was the closest one to my build, was damaged and was giving out way more electricity than it should’ve. Burned everything after a few minutes I plugged it in
Had something similar happen the other day at work. RMA department came looking for a sata cable because they got a psu that was missing one, I gave them what i thought was for the correct model… It wasn’t… There was a custom daughter board in that system that went up in smoke I just wiped my hands and said “should have checked with a multimeter first”
