Possible windows problem,need help
Alright so here is the deal.Every once in a while my monitor goes black.My pc runs fine,all is good and well,then all of a sudden bam,lights out.My screen just goes black,I can hear the basic background noise of the program I was running,a game or something,my pc is still on and running but my screen is black and my pc is not responding.After I restart manually windows asks me if i want too start the pc normally.I have windows 7 ultimate 64 bit.I have looked it possible hardware and other software problems and did not find anything wrong.the temps are fine as well.The last time this happened I ran Advanced System Care and it found a registry problem in windows that needed fixing.I am pretty lost right now,dunno what too do,install different windows maybe ? Maybe my Asus drivers for my HD7790 card aren't good ? I am at a wall
  • drivers >> grab latest amd files, uninstall current ones, run driversweeper, install latest ones
  • monitor >> does this happen on another system? if so buy a new monitor
  • gpu >> try gpu in another system, if same thing happens RMA the card
  • windows corruption >> reinstall and start again.
