Not sure if this is the right place or even worth asking but here it goes.
Found an old PC when cleaning out my Grandmother's basement. Looks to be a mid 2001 Del Dimension 4400. Pentium 4 at 1.6GHz, 1GB of DDR RAM, nVidia GeForce3 Ti500, 40GB HDD, Windows XP Pro. Boots up and works fine. Little slow but it works.
Any possible uses for this thing? I was just planning on using it as a target but if anyone has any better suggestions I'd like to hear them.
If I do shoot it I'll be sure to post the video haha
Unless you hide that thing back in the basement when it's on, it will be the most annoying thing that has happened to you. Those things tend to get very loud.
Or you could try and get your hands on some arcane device that only has driver support for Win 98. Get a needle printer with continuous paper support and then print away (if you have a basement).
