I’d like to build in the Streacom DB4. I’d also like to use Gentoo with it, which may or may not be a problem. I compile all my software, the biggest being Firefox. A simple window manager (i3wm) and Firefox.
Ideally I would use a AMD Ryzen 2400G 45-65W (or possibly AMD Athlon 200GE – 35W).
How stressful would compiling programs be? Would the passively cooled Streacom DB4 be able to handle it?
I don’t see how gentoo or compiling would have anything to do with cooling.
If your priority one is fanless, you match case and CPU and you’re good. The CPU has a TDP which your case should be able to cool. Anything beyond that is not primarily about silence anymore. If your Case can support your CPU’s TDP, it’ll be fine running at 100% load for a long time. It’ll probably not boost or throttle a bit, and it won’t be running at 40°C, but your requirements are neither performance nor running cool, but silent.
If you want great performance, temps AND Silent, that’s when it gets tricky to impossible…
Big +1 to distcc if you want to compile on another machine. Also, if you want to be cheap, you can emerge firefox-bin to save some time (at the cost of your Gentoo street cred)
firefox is shit anyway. Barely any use flags, no way to compile it without the shitty built in notification system. The only reason to emerge firefox over firefox-bin is to have it compile with the many patches that attempt to unfuck mozillas shitfest
Yeah and they’re only going downhill apparently. I’m a Vivaldi guy, but I would be using surf if I could get video working. Everything just looks red for some reason lol
