Possible DDR 5 stability issue
I’m having stability issues, intermittently. Usually on cold startup. I noticed it on anything from simply having discord on and crashing. To it not seen devices or even losing keyboard and mouse control , a reboot, usually solves it. With all the DDR5 cooling issues I’m hearing about. I had a spare 120 sitting around so I put that directly pointing at the memory sticks to see if it helps. If so, I will probably get myself some small 40 mm fans and 3D print a bracket for it.
Does anyone else seem to be having issues with stability was similar platforms.
Custom water cooled , 360 rad & 280 rad with CPU and gpu blocks
9950x
Msi x870e carbon WiFi
CORSAIR Vengeance DDR5 RAM 128GB (2x64GB) 6400MHz CL42-52-52-104
Boot- Samsung 990 Pro 2 Tb &
SAMSUNG 970 EVO Plus SSD 2TB
Rtxa5000 gpu
Corsair HX1000i Psu
phanteks p600s case
Occasionally do some light gaming.
Primarily used for fusion 360, bambu studio.
ICUE open running on my second monitor. To watch hardware Info. Maybe a browser or two open.
I never had these issues when I was running my 5900x with 96 gb mem.
What are your memory settings? What are the memory temperatures (check HWinfo)?
If you have crashes when opening discord on a cold boot it’s highly likely your current memory settings are simply not stable regardless of temperatures. Under these conditions your memory simply won’t be warm yet.
Do stability tests both at stock settings (5600 auto) and 6400 (expo?) and keep an eye on temperatures.
More typical symptoms of instability due to temperature are long running memory intensive calculations (number crunching, compiling, …) or when gaming (GPU heating up case temperatures).
Fan on the memory definitely dropped the temperatures by 12 C. I’m now running at 25.5 C during normal operating. I also found out that the house had a floating ground issue. Which was making its way through in spite of having a UPS. Fortunately, I know a little bit about electrical. I will probably still drop my clocks from 6400 down to 6000. Voltage is averaging 1.33.
Thank you. If you think of anything else that might help my system in temps or stability feel free to post it and I will give it a try.
I did have stability issues with my G.skill 6000 CL30 AMD EXPO kit.
Weirdly it would report pretty normal temps while it would go unstable, so either its was lying or it wasnt measuring whatever part of the kit was overheating. Its one of those RGB kits, so full heatsink cover.
Re-did my case airflow to have 2 fans on top as exhaust (through CPU AIO radiator) and everything else (2x front, 1x rear) as intake and gave top fans a bit higher profile and that helped keep them stable, but in the end i bought another kit from Kingston, cuz i didnt like the fact i couldnt detect the memory overheating before it would crash everything…
No issues with Kingston kit, but i decided to run it at 5600 / 1.25V instead of 6000 / 1.35V profile to keep it a bit more cool, cuz memory be expensive :smiley:
