The story:
I am running unRAID on my home media server. I was moving tens of TBs of data from one server onto unRAID and over-filled some of the drives. I have plenty of space on the pool (Total: 175 TB, Free: 58.3 TB), so now I would like to move some files of those over-filled drives, into the emptier ones.
All drives on my unRAID have XFS file system on them.
The goal:
All those over-filled disks have mostly been filled in one swoop - as in I used Midnight Commander and moved files from one disk onto another, until that one was “full”.
When I was moving the files onto those drives, I assume the files were written to the disks in the manner of fastest disk place to slowest
. If that’s true, I would like to move the latest
files, as they would be in the slowest place on the disk (I assume nearest to the center of the platters).
I am a total linux newb, so lemme say sorry in advance, if my questions are silly…
Questions:
- Am I right assuming, that XFS filled up the disks like I’ve described: fastest-to-slowest disk place?
- If yes, how can I find out which files where written to the disk the latest?
- One idea I had, is maybe using the
inodes
? Does XFS create the inodes sequentially?
I mean, if it does, I could sort files by inodes (from smallest to largest number), and this way I could find out, which files should belatest written onto disk
, and which ones should I move of… - Maybe there is some other, better/easier “linuxy” way to achieve this? A bash command, or script?
I hope I am making some sense…
Thanks in advance for any help.
