Portainer ce
Since Portainer CE will not be receiving any new features or upgrades, just security updates, i went looking for for something else.
Heres what i found:
Since i already run cockpit, i started looking for a plugin for that, and found a decent one.
I installed all the cockpit plugins fedora offered. Then i found this:
Installed this and it works fine. It has all the core features i use all the time, and i while portainer has many more features, i wasnt using them much and can do those via the docker command at the command line as needed.
Local
Remote -main docker server (not all are in the picture below)
I am working on something like that with some more features:
https://forum.level1techs.com/t/what-are-you-working-on-today/167475/5670?u=mietzen
But it’s not fully done yet. But you may test it if you want:
