Hi everyone I have been researching the best external portable hard drives lately because I need reliable storage for backing up files, photos, and important data. I’m looking for something that’s dependable, easy to use, and portable enough to carry with my laptop when needed. Data safety and long-term reliability are really important to me.I’ve checked several reviews and also looked through verified customer feedback. After comparing different options, these two brands kept coming up as strong choices:
• Seagate External Portable Hard Drive
https://www.amazon.com/Seagate-Portable-Hard-Drive/dp/B07VS8QCXC/
• WD (Western Digital) External Portable Hard Drive
https://www.amazon.com/Passport-Portable-External-Drive-Black/dp/B07VTFN6HM
However, I’m having trouble deciding which one would be the better option, and I’d really appreciate some advice from people who have used either of these drives.For context, I mainly want the drive for backups, storing media files, and everyday file transfers. Good durability, fast transfer speeds, and dependable performance over time are my top priorities.Which one would you recommend? Any pros, cons, or real-world experiences would be really helpful. Thanks in advance!
