I followed Setting up PIA VPN on pfSense for your whole network and Configuring Selective Routing by Lawrence System on YouTube. Almost everything worked as excepted. The only problem was that I could not get port forwarding to work, it worked perfectly fine before I dabbled with the “VPN stuff”. I.e., I want to have a server outside of the VPN part of the network, which I can access remotely. How would I go about accomplishing this?
My current firewall rules for WAN, which is working when VPN-client is not enabled.
Outbound NAT setup from the video, my setup looked the same before I reverted my pfSense config to one without a VPN-client enabled.
Thanks, in advance!
Best regards, Elias, a pfSense beginner.
