Pop! OS Freezing Randomly
I posted this on Reddit but I have not gotten any help yet.
So I installed the version without the Nvidia drivers and now after a few hours of use my OS will randomly crash. I found a post relating to configuring Nvidia drivers but I don’t have that file being I didn’t pick the one with the drivers so I am guessing mine is crashing/freezing for a different reason.
I have not been playing games with it. The only things I have been using on it are Emacs and Chrome. Regardless of what I do it seems to crash. I am unsure how to get diagnostics or logs at the moment it crashes to determine the cause.
Here is my system info.
GPU : 780ti
cat /etc/*-release:
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=19.04
DISTRIB_CODENAME=disco
DISTRIB_DESCRIPTION=“Pop!_OS 19.04”
NAME=“Pop!_OS”
VERSION=“19.04”
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME=“Pop!_OS 19.04”
VERSION_ID=“19.04”
HOME_URL=“https://system76.com/pop”
SUPPORT_URL=“http://support.system76.com”
BUG_REPORT_URL=“https://github.com/pop-os/pop/issues”
PRIVACY_POLICY_URL=“https://system76.com/privacy”
VERSION_CODENAME=disco
UBUNTU_CODENAME=disco
lscpu:
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
Address sizes: 43 bits physical, 48 bits virtual
CPU(s): 16
On-line CPU(s) list: 0-15
Thread(s) per core: 2
Core(s) per socket: 8
Socket(s): 1
NUMA node(s): 1
Vendor ID: AuthenticAMD
CPU family: 23
Model: 8
Model name: AMD Ryzen 7 2700X Eight-Core Processor
Stepping: 2
CPU MHz: 2335.818
CPU max MHz: 3800.0000
CPU min MHz: 2200.0000
BogoMIPS: 7598.84
Virtualization: AMD-V
L1d cache: 32K
L1i cache: 64K
L2 cache: 512K
L3 cache: 8192K
NUMA node0 CPU(s): 0-15
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb hw_pstate sme ssbd sev ibpb vmmcall fsgsbase bmi1 avx2 smep bmi2 rdseed adx smap clflushopt sha_ni xsaveopt xsavec xgetbv1 xsaves clzero irperf xsaveerptr arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif overflow_recov succor smca
Disable c states/power management for testing?
Make sure psu idle current is set to typical in uefi?
Disable gear down mode (around ram settings)?
Scratch what I just said…
under advanced\AMD CBS I found it mentioned.
Now I am searching how to disable gear down mode…
mine keeps randomly freezing as well. it happens in pop os only. windows and ubuntu works fine
