Hi all,
I’m looking for some guidance regarding CPU temperatures after a recent upgrade and whether what I’m seeing is expected or not.
A few months ago, I upgraded my system from an older first-generation AMD setup to the following:
CPU: Ryzen 7 1700X (8-core, 16-thread) → Ryzen 7 5700X (8-core, 16-thread)
Motherboard: MSI MPG B550 GAMING PLUS (MS-7C56, revision 4.0)
RAM: Mixed kits (all running at 3200 MT/s):
2 × 8GB G.Skill F4-2400C15-8GTZR
2 × 16GB G.Skill F4-3200C16-16GTZR
When I made the upgrade, I kept using my older AMD stock cooler from the previous build instead of replacing it. My assumption was that since the newer CPU has a relatively efficient TDP, the cooler would still be sufficient, but I’m starting to question that.
The Issue
Since the upgrade, I’ve noticed that my CPU temperatures seem higher than expected. I’m trying to understand whether:
These temperatures are normal for a Ryzen 7 5700X
The older stock cooler is no longer sufficient
Or if the readings I’m seeing are not accurate
Monitoring Tool
I’m currently using:
Psensor on Pop!_OS 22.04 LTS
Sensores
So I’d like to ask:
How reliable is Psensor / lm-sensors for CPU temperature readings on Linux?
Should I be validating this with another tool?
Could this possibly be a Pop!_OS-related issue (sensor reporting, kernel behavior, etc.), or is that unlikely?
As you can see from the graph in Psensor, the CPU temperature is constantly fluctuating. It tends to hover around 45°C, then rises and drops repeatedly in a continuous cycle. At the same time, I can clearly hear the system reacting, where the fans spin up to cool it down, then slow down once the temperature drops, and then ramp up again shortly after. This pattern keeps repeating even during light usage, so it feels like a constant loop of heating and cooling. I’m trying to understand what exactly is causing this behavior, whether it is normal boost or thermal management for this CPU, a limitation of the older stock cooler, or possibly something related to sensor reporting or the OS itself.
BIOS Situation
Another factor is that I’ve never updated the motherboard BIOS and it’s still running the factory version.
I’m a bit reluctant to update it because I previously had a bad experience where a BIOS update bricked an older system.
So I’d appreciate some insight on:
Could an outdated BIOS affect CPU temperature behavior or power/voltage management?
Would updating the BIOS improve how the motherboard handles the CPU (boosting, thermals, stability)?
Or is this unlikely to make a noticeable difference compared to upgrading the cooling solution?
I can provide exact idle and load temperatures if needed.
Thanks in advance for any advice.
