Hello
I installed Pop_Os 19.04 from a usb stick to my hard drive and now I can’t boot into the Os itself. I completely erased the hard drive before I installed it. When I power on the laptop I get the Grub menu and then I press on the word that says Ubuntu and nothing happens. I only get black screen. Could somebody please help?
My laptop specifications:
CPU:
AMD A10-5750M
RAM:
6 GB
HDD:
1TB
CONNECTIONS:
USB 3.0 x 2, USB 2.0 x 1
2x1 (SD/MMC)
2-in-1 audio jack (headphone and mic)
HDMI-out
RJ45
VGA connector
When at the black screen, what happens, if anything, if you press the following keys?
ctrl + alt + F3
Also, I added some tags to the thread. So if you see a notification with a pencil, that’s what that is.
Nothing happens if I press those buttons.
I also forgot to mention in the description that my laptop is a Lenovo G505s.
you may need to press the Fn button to get F3 to work. I think you can toggle the function keys is you press Fn+Esc
btw, I don’t think pop_os uses grub by default
Apparently it does because I didn’t do anything else except install Pop_Os.
I found this on their website.
Systemd-boot is the bootloader for Pop!_OS 18.04 and above while GRUB is the bootloader for Ubuntu.
Interesting. I never knew systemd-boot was a thing.
I tried the above mentioned solution but when I get to the logo and press and hold F7 and F1 buttons nothing happens. Regardless if I’m using stand-alone keyboard or keyboard on the laptop.
My first question would be… did you download the correct version from the pop os site ?
You want the intel/amd version of pop os. Did you use etcher to flash the usb ?
Mine was a little slow this morning to get into full boot of pop os the first time. That was on a full desktop.
It was intel/amd version and I used Rufus for flashing.
I went back to Windows which mean we can end this conversation. Thank you for trying to help me, but I simply don’t have the nerves anymore to go back and forth with Linux.
to fix the issue u only need follow this video #youtu.be/atGkorVI5Bw
I had a similar issue when I first installed pop!_OS.
Turned out to be an issue when selecting enlgish language with Swedish keyboard(in my case)
I ended up trying english with standard english keyboard and it booted fine.
Figured I should mention it, I’m not sure if that bug is still present. But if you tried to install with a non english keyboard. Give this a try and just install your native keyboard after the install.
It’s one year later. OP has moved on.
