Just did a fresh install of Pop!_OS 19.04 on my work PC and am having a strange issue with my triple monitor setup. If I open settings and go to the displays section my screens will flash and my 2 1080p screens will get combined into a single display (labeled 2-3). See video:
Logging out and back in will fix the problem until I open settings again.
Specs:
ASRock x299 Taichi XE
Intel Core i9-7900x
64gb DDR4
AMD Radeon Pro WX 5100
1TB Samsung 970 Pro SSD
That’s an interesting quirk. I would probably file a bug with the Pop!_OS team. Why are you constantly entering display settings in the first place though?
A workaround could be to use the xrandr tool to place the screens where you want them. Open a terminal and type xrandr, you should get something like this;
This command lists all connected screens and their supported resolutions. In order to move your screens around, split them etc. you can do a lot of fun stuff. For instance, this rearranges all screens to be “stacked” on top of each other:
And this sets a screen resolution on a single screen:
$ xrandr --output HDMI-0 --mode 1920x1080
I also think xrandr allows you to define a screen to be stitched together with multiple outputs, or a single one, and that is what is happening here. Read man xrandr for further information.
