Poor performance with 5600xt in Guest VM
I have a VM setup with a 5600XT that has extremely poor performance. My benchmark is SOTR which hits 60FPS consistently on bare metal at 1080p as opposed to 10-20FPS on the VM.
Just a quick history, I had this VM working perfectly with a R9 390 for many years, swapped with a RX 470 when support for the 390 ended and that worked perfectly until I gave it away. I then transferred this 5600xt that came from another machine last year and ran into this issue of poor performance. I honestly never tried much to troubleshoot it as I would primarily run games on the host which has a 6600xt.
I can’t recall changing any settings on the VM from since running the 390 and 470 so I am not sure what may be causing the issue. I want to mention that the 5600XT did require the vendor reset that works perfectly as I can start, stop and restart VM without issues.
From the past I can recall my major hiccups with VFIO performance where not having the hyper V enhancements enabled and the most significant difference came from having a physical HDD passed through which are exactly what I am using now which has me confused.
It was only during the holidays with I tried to play some multiplayer games with a friend that sh!t hit the fan with games like AOE4 multiplayer not working, requiring some fixes etc to resolve those issues which basically killed the mood of the entire session where I then realized that I need to get the VM working again. I have been gaming via proton successfully for the past few years primarily for single player usage and have not used the VM or even kept up with recent advancements with VFIO so maybe there might be something I am overlooking in the setup.
Specs:
  • OS - Ubuntu 23.10
  • CPU - 3800X
  • Host GPU - 6600XT
  • Guest GPU - 5600XT (Win10)
<domain type='kvm'>
  <name>win10_vfio</name>
  <uuid>9639211b-8cd4-4418-bfd9-eb5ee187c0db</uuid>
  <memory unit='KiB'>16777216</memory>
  <currentMemory unit='KiB'>16777216</currentMemory>
  <vcpu placement='static'>8</vcpu>
  <iothreads>4</iothreads>
  <cputune>
    <vcpupin vcpu='0' cpuset='4'/>
    <vcpupin vcpu='1' cpuset='12'/>
    <vcpupin vcpu='2' cpuset='5'/>
    <vcpupin vcpu='3' cpuset='13'/>
    <vcpupin vcpu='4' cpuset='6'/>
    <vcpupin vcpu='5' cpuset='14'/>
    <vcpupin vcpu='6' cpuset='7'/>
    <vcpupin vcpu='7' cpuset='15'/>
    <iothreadpin iothread='1' cpuset='4-12'/>
    <iothreadpin iothread='2' cpuset='5-13'/>
    <iothreadpin iothread='3' cpuset='6-14'/>
    <iothreadpin iothread='4' cpuset='7-15'/>
  </cputune>
  <os>
    <type arch='x86_64' machine='pc-q35-2.12'>hvm</type>
    <loader readonly='yes' type='pflash'>/usr/share/OVMF/OVMF_CODE.fd</loader>
    <nvram>/var/lib/libvirt/qemu/nvram/win10_vfio_VARS.fd</nvram>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv mode='custom'>
      <relaxed state='on'/>
      <vapic state='on'/>
      <spinlocks state='on' retries='8191'/>
      <vpindex state='on'/>
      <synic state='on'/>
      <stimer state='on'/>
      <reset state='on'/>
      <frequencies state='on'/>
    </hyperv>
    <vmport state='off'/>
  </features>
  <cpu mode='host-passthrough' check='none' migratable='on'>
    <topology sockets='1' dies='1' cores='4' threads='2'/>
  </cpu>
  <clock offset='localtime'>
    <timer name='rtc' tickpolicy='catchup'/>
    <timer name='pit' tickpolicy='delay'/>
    <timer name='hpet' present='no'/>
    <timer name='hypervclock' present='yes'/>
  </clock>
  <on_poweroff>destroy</on_poweroff>
  <on_reboot>restart</on_reboot>
  <on_crash>destroy</on_crash>
  <pm>
    <suspend-to-mem enabled='no'/>
    <suspend-to-disk enabled='no'/>
  </pm>
  <devices>
    <emulator>/usr/bin/kvm-spice</emulator>
    <disk type='file' device='cdrom'>
      <driver name='qemu' type='raw'/>
      <target dev='sda' bus='sata'/>
      <readonly/>
      <address type='drive' controller='0' bus='0' target='0' unit='0'/>
    </disk>
    <disk type='block' device='disk'>
      <driver name='qemu' type='raw' cache='none' io='native'/>
      <source dev='/dev/sdd'/>
      <target dev='vda' bus='virtio'/>
      <boot order='2'/>
      <address type='pci' domain='0x0000' bus='0x06' slot='0x00' function='0x0'/>
    </disk>
      <source dev='/dev/sde'/>
      <target dev='vdb' bus='virtio'/>
      <boot order='1'/>
      <address type='pci' domain='0x0000' bus='0x07' slot='0x00' function='0x0'/>
    </disk>
    <controller type='usb' index='0' model='ich9-ehci1'>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1d' function='0x7'/>
    </controller>
    <controller type='usb' index='0' model='ich9-uhci1'>
      <master startport='0'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1d' function='0x0' multifunction='on'/>
    </controller>
    <controller type='usb' index='0' model='ich9-uhci2'>
      <master startport='2'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1d' function='0x1'/>
    </controller>
    <controller type='usb' index='0' model='ich9-uhci3'>
      <master startport='4'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1d' function='0x2'/>
    </controller>
    <controller type='sata' index='0'>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
    </controller>
    <controller type='pci' index='0' model='pcie-root'/>
    <controller type='pci' index='1' model='pcie-root-port'>
      <model name='pcie-root-port'/>
      <target chassis='1' port='0x8'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='2' model='pcie-to-pci-bridge'>
      <model name='pcie-pci-bridge'/>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
    </controller>
    <controller type='pci' index='3' model='pcie-root-port'>
      <target chassis='3' port='0x9'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x1'/>
    </controller>
    <controller type='pci' index='4' model='pcie-root-port'>
      <target chassis='4' port='0xa'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x2'/>
    </controller>
    <controller type='pci' index='5' model='pcie-root-port'>
      <target chassis='5' port='0xb'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x3'/>
    </controller>
    <controller type='pci' index='6' model='pcie-root-port'>
      <target chassis='6' port='0xc'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x4'/>
    </controller>
    <controller type='pci' index='7' model='pcie-root-port'>
      <target chassis='7' port='0xd'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x5'/>
    </controller>
    <controller type='pci' index='8' model='pcie-root-port'>
      <target chassis='8' port='0xe'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x6'/>
    </controller>
    <controller type='pci' index='9' model='pcie-root-port'>
      <target chassis='9' port='0xf'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x7'/>
    </controller>
    <controller type='pci' index='10' model='pcie-root-port'>
      <target chassis='10' port='0x10'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='11' model='pcie-root-port'>
      <target chassis='11' port='0x11'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x1'/>
    </controller>
    <interface type='bridge'>
      <mac address='52:54:00:95:a8:77'/>
      <source bridge='br0'/>
      <model type='virtio'/>
      <address type='pci' domain='0x0000' bus='0x09' slot='0x00' function='0x0'/>
    </interface>
    <input type='mouse' bus='ps2'/>
    <input type='keyboard' bus='ps2'/>
    <input type='keyboard' bus='virtio'>
      <address type='pci' domain='0x0000' bus='0x0b' slot='0x00' function='0x0'/>
    </input>
    <audio id='1' type='none'/>
    <hostdev mode='subsystem' type='pci' managed='yes'>
      <source>
        <address domain='0x0000' bus='0x12' slot='0x00' function='0x0'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x12' slot='0x00' function='0x1'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x14' slot='0x00' function='0x3'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x08' slot='0x00' function='0x0'/>
    </hostdev>
    <memballoon model='virtio'>
      <address type='pci' domain='0x0000' bus='0x05' slot='0x00' function='0x0'/>
    </memballoon>
    <shmem name='looking-glass'>
      <model type='ivshmem-plain'/>
      <size unit='M'>32</size>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x01' function='0x0'/>
    </shmem>
  </devices>
</domain>
this might be relevant.
seems it might be your using a kernel thats out of date for the hardware.
I have a 7900xt on Bookworm and it works fine.
The kernel lists itself as 6.1.0-x but the real issue is the version of Mesa for support of the card. Of which Bookworm has a compatible version, 22.3.6, and I can attest it works out of the box.
Current kernel is 6.5.0-14-generic and Mesa is 23.2.1.
I am tempted to redo the VM from scratch as this config is from 2018 or so. I am not sure if there are some stuff missing when compared to newer generated config xml or if that would even matter?
as long as the distro is updated then there shouldn’t be anything missing.
you could run a apt/apt-get full-upgrade/dist-upgrade and see if that sorts it. (both will add or remove dependencies along with sorting conflicts)
if it doesnt then renewing the vm isnt the worst idea.
From what I understand you really need mesa >=22.3 for it to work as expected. So you should be good since you have one major version higher.
So I just tried creating a new quick and dirty VM with just the Drives and 5600xt passed through and got a smooth and consistent 30fps on SOTR benchmark. I double checked the refresh rate and it was changed to 29hz for some reason. Changed that and ran the benchmark again for a smooth 60fps.
I am not sure what went wrong with the original xml config but I guess some setting was causing an issue as this new VM was created with no tuning and it performs great.
That shouldn’t be an issue as the device is being passed though to the VM without the Linux graphics modules being involved
