Please help with the PSU!
Hi everyone!
The current build that i want is this:
CPU:Phenom || x4 965 BE
motherboard:gigabyte GA-990FX UD3 AM3+
GPU:Radeon HD 7870 HIS
RAM:G skill ripjaws X 8Gb
HDD:western digital caviar blue 500GB
Case:CM storm enforcer
So the problem is there are so many PSUs that i dont know wich one to choose?
Thanks for the help!
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207022
http://www.newegg.com/Product/Product.aspx?Item=N82E16817194086
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151088
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151106
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438007
here a list of very good psu´s, but ofc there are many more good brands, just make sure you but a 650W/750W 80+ Bronze or better, and take a  good brand, like Enermax XFX seasonic Coolermaster some crosair models. EVGA
Rosewill Capstone 650 Modular PSU; great build quality, fantastic value, and 80+ Gold efficiency.
I readed about Rosewill psu´s to seems also be a very good brand. no where to find in the Netherlands..
Check out Tagan, it's a lesser known Taiwanese brand that does a lot of OEM work for redundancy critical systems, but also have a small desktop line. In all tests I've done with an oscilloscope, they have been the PSU's with the most constant sine wave. I have used them for my systems and for customer's systems for years (about since 2005), and not one single PSU has given problems (knock on wood). Especially if you use internal audio solutions and you want superior audio quality, and want to overclock quite a bit, Tagan is a really good choice imo.
The Tagan PSUs are out of stock...
Oh and sorry but i forgot to mention something.Can you recommend a PSU that isnt very expencive i mean around 60-70 mybe ?
