Just rebooted and rans test for an hour… errors galor. No idea. Didn’t change anything. ![]()
I guess need more tinkering, but what to tinker. I think I will just RMA this and get something else. I been at this for four days.
I will re-iterate that… if it’s not the QVL… you’re going to be playing the silicon lottery for sure… since especially at that capacity and speed it’s untested.
I stuck to the QVL, just bumped the DRAM voltage to slightly above stock as mentioned… nothing more
I would not have much experience with gigabyte … but i imagine the QVL is very important north star for getting the full memory stable…
did down clocking not help?
One more thing
Change it back to 3600 and then on the UCLK DIV1 MODE, change it to /2
This cuts your memory controller speed in half but should extend the speed you can run
I doubt this has anything to do with QVL, you’re overclocking and it doesn’t work…
If you reset to stock settings in BIOS, disable any “tweaking app” set memory speed to 2666 (if it doesn’t default) and run memtest86+ for a good 6-12 hours. Do you get any errors?
I spoke to support who I was on the phone to for an hour. Ended up setting up an RMA, and have sent it back to them. They said they would refund me.
He mentioned, the thing with the QVL for this board is that its an older generation and so that QVL hasn’t been updated for over a year or two.
Priorities have likely shifted in Gigabyte to run tests on their newer products. And its hard to get chips now that ARE on that QVL, especially with what I am looking for anyway.
So, the closest thing that I have found on the QVL is CMK128GX4M4C3200C16, but it isn’t available to buy anywhere online… however, a close match they did sell was CMK128GX4M4E3200C16.
I have pre-ordered the E set and hoping I will have better luck.
Failing that, I will just return it and consider upgrading my whole system entirely to a newer platform, AM5 or Intel equivalent.
Thank you once again so much L1!! orz
I tried this also, took off XMP and all adjustments so it was running at 2666 or something. I ran TM5 extreme and still got errors.
I think doesn’t necessarily always mean there’s a problem with the memory, but potentially configuration. I.e. it is just too much for the MC or not enough voltage in XYZ etc.
I guess leaving things on AUTO in BIOS is a bad idea huh.
I haven’t read the whole thread but have you tried each stick individually yet
Yes I did try them individually, even with XMP off and all settings defaulted. Still got errors.
I have returned it though and got another set.
Tested the new set gradually, one stick at a time, no XMP, then XMP, and not a peep. Not one error.
All four 32 GB are in at XMP 3200. No fiddling with timings or anything.
BTW the new set is CMK128GX4M4E3200C16
I couldn’t find anything on this set anywhere. Even the Corsairs page doesn’t list the E model revision.
Further, the serial numbers are different - starting A4VET…
from what I am familiar with seeing - 180203… (Year-Week-etc)
It is a Hynix 16Gb M-die apparently, again. I was hoping for Samsung B ![]()
Wow every stick was bad huh
