Cominco
December 30, 2012, 1:31am
#1
Ok so I've put all of my parts together for my build. I have a asrock extreme4 and an i3 3220 with a xfx 550w power supply. Ive connected all the cables and I go to hit the power button on the motherboard.... and nothing.
Please help!
Also I purchased 1.65v ram and i wanted to take it back for 1.5v but the manager assured me that 1.65 would work
Cominco
December 30, 2012, 1:43am
#4
what does that mean
also i dont think the powersupply is broke because when i plug the 6 pin connections into my graphics card green l.e.d's light up
Rinzler
December 30, 2012, 1:47am
#5
motherboard is probably making contact with the case, I made the same mistake myself.
check all your pegs and the motherboard backplate.
Rinzler
December 30, 2012, 1:51am
#7
post some photos of it too, it'll help make diagnosing the problem a little easier (for all of us).
Cominco
#8
Should I try a boot up with my stuff outside of the case?
Rinzler
December 30, 2012, 1:56am
#9
try with putting in one componant at a time and check every connection.
you should be able to get a bios splash from the vga on the mobo board.
Cominco
December 30, 2012, 2:01am
#10
http://imgur.com/Ol34g
http://imgur.com/DbGe0
I know the quality is bad
Cominco
December 30, 2012, 2:15am
#11
OMG ok i took the motherboard out of the case and it works! now i know its not doa
Rinzler
December 30, 2012, 2:17am
#12
don't worry about the quality, just get some light on the backplate and try to get a close up, from the inside. also how tightly did you screw it down?
Cominco
#14
How long should It take before i get to a screen
Rinzler
December 30, 2012, 2:20am
#15
a good build should take an hour or two, but since this is your first one there's an acception :).
shouldn't take long at all. then you should be able to plug everything back in once the mobo board is seated correctly
Cominco
December 30, 2012, 2:27am
#16
Ok uefi bios screen came up, now to put it all back in the case
thanks a lot man
Rinzler
December 30, 2012, 2:46am
#17
Good luck with the rest of the build and happy gaming. If you need more help i'm always available on steam
