So I'm for sure ordering this today and I wanted final expert opinions. Here it is:http://pcpartpicker.com/p/1jzlf
I really like this build but I just wanted to get final expert opinions on it. Also will the PSU i picked be able to Crossfire the 7850? I will be doing heavy gaming and Overclocking with a goal of 4.2 to 4.5 GHZ. And if your going to suggest me a build please keep these factors in mind:
I don't need OS peripherals, monitor
I need a Wifi Card
I need an optical drive
CPU cooler
Case has to look beastly!
CPU Overclockable
Crossfire ready
1080p gaming on very high to max settings.
Thanks TekSyndicate for all the help as of late! My venture into PC gaming is soon complete thanks to you guys!
2, if you what to crossfire get a 990FX chip set mobo (that 970 runs one pcie x16 slot at x4 speed and one at x16 speed)
3, you may need a bios update for that motherboard if you dont get a bang up to date vershon off the shelf
4, yes that psu is good enuff for x2 7850's
5, for over a 1ghz overclock look at geting a Noctua NH-D14 or a Phanteks PH-TC14PE
Allso its going to be a real tight fit with the pcie 1x wifi card if you have 2 card crossfire it will depend how large thay are if you will be able to fit it in there
Made necessary changes. Lower priced power supply with less ripple, and a better board for overclocking. Never expect a good overclock on a 970 board. You can get a "fair" OC, but never anything huge.
