Given that DLSS limits the steps artificially I thought I might use DLDSR and see if I can enable different options and see how this affects performance. I did all tests on my 3090 with DLSS 2.4.3 on my 5120x1440 screen in Cyberpunk 2077. Granted, my results might not give a broad overview but I did have some insight I wanted to share.
First, some information about DLSS’ scaling factors in relation to the modes. As to my knowledge, this factor is applied to the vertical pixel for calculation and not the overall pixels. Thus DLSS Quality on 5120x1440 results in 3413x960 being the render resolution.
- Quality uses 2/3
- Balnced uses 0.58%
- Performance uses 0.5%
Additionally, DLDSR has the following two downscaling options:
- 1.75 → 6826x1920
- 2.25 → 7680x2160
So, I combined the scaling factors with a few different DLSS options and ran the Cyberpunk 2077 benchmark with the following results:
Min FPS | Avg FPS | Max FPS | |
DLSS Quality (960p) | 37.16 | 46.31 | 59.45 |
2.25 - Performance (1080) | 27.75 (-25%) | 34.53 (-25%) | 43.56 (-26%) |
1.75 - Balanced (1113p) | 27.31 (-1%) | 34.03 (-1%) | 43.55 (0%) |
2.25 - Balanced (1252p) | 21.68 (-26%) | 27.67 (-19%) | 35.85 (-18%) |
1.75 - Quality (1280p) | 21.24 (-2%) | 27.37 (-1%) | 36.26 (+1%) |
As one can see from this benchmark both 2.25 options perform slightly better than the 1.75 ones and therefore I would just use 1113p or 1280p depending on the free performance available.
If a 4090 for instance will double the performance compared to a 3090 as rumor has us believe, the following result could be possible:
DLSS Quality (960p) | 74.32 | 92.62 | 118.9 |
1.75 - Balanced (1113p) | 54.62 | 68.06 | 87.1 |
1.75 - Quality (1280p) | 42.48 | 54.74 | 72.52 |
However, for some people 1280p will not offer acceptable performance, but then again it is up for everyone to decide.
Thus, with this neat little trick, the following DLSS options have become available:
- Extreme Quality: 0.88
- Ultra Quality: 0.77
- Quality: 0.66
- Balanced: 0.58
- Performance: 0.5
- Ultra Performance 0.33
Has someone else here given something like this a try? I would be interested in your results.
Edit: Added tables, special thanks to @Zibob
