Picking a motherboard for Threadripper 5000 from ebay
I think the prices of the 3000/5000 series Threadripper stuff came down enough that it might be worth upgrading one of my older TR systems. I settled on TR 5000.
I mostly just need lanes + slots, cores not so much. The 5945WX is fine, but I saw some mobo+cpu combos with 5955WX. I figured I would likely get a combo that actually would work together and arrive together, so that might be a good route.
I’m not sure about the motherboard. My requirements are:
  • PCIe Gen4
  • 256GB DDR4 Unbuffered ECC memory (re-use from previous system)
Nice to have:
  • bifurification to at least x4x4x4x4 is a strong preference
  • built-in U.2 connectivity (i have a x16 to 4 u.2 breakout adapter thingy so no big deal)
These are the boards that I came across:
Right now I mostly want to run 3-4 graphics cards for AI evaluation under Proxmox. I also have a Seasonic 1600W Titanium.
I’m in Europe, so most likely my order would be coming from Asia, not dealing with US. I once got a faulty Threadripper from there so I hope I can rely on seller reputation.
WRX80 Creator R2.0 is <600€ new and available, for example https://www.mindfactory.de/product_info.php/ASRock-WRX80-Creator-R2-0-AMD-WRX80-So--sWRX8-DDR4-EATX-Retail_1473504.html
TRX50 boards can be had for around 600€ too, although 9960X will run you 1100€ and you’d need DDR5, which is craaaaaazy expensive now.
I personally have a 5955WX + WRX80 Creator R2.0 + 8x32GB 3200MT/s CL22 ECC and I was contemplating to “upgrading” to 9950x + 4x64GB but with the RAM prices now that idea is on hold. (got a WTS thread here cough but yeah, on hold!)
If memory bandwidth is relevant to your workload, you should know that the low-core models have less CCDs and thus less memory bandwidth.
Thanks, I’ll look into the Creator, although I’m not a fan of MSI boards brain fart, I’m dumb, it’s ASRock, them I like.
I’m definitely not going to 7000/9000 series because I don’t have the RAM for it.
I checked out the Creator, I didn’t like that there are two slots that were made x8, instead of the single x8 on other boards. Also it only has one U.2 connection whereas others have 3.
Saw a video review of the Sage and it seemed a bit quirky.
The Gigabyte MC62-G40 is still a contender, but the L1T review of it mentioned that it doesn’t have a separate aux power for the PCIe slots and running multiple video cards, which I plan to do, will not work. Since I looked at a lot of WRX80 boards, they all look very similar to each other, and in a different board’s manual one of the 8pin connectors was labeled at PCIe power. Not sure how I could find out more. Also in another thread someone said their board died, and since I’d be getting these off ebay as pre-owned, it’s a bit risky.
The Gigabyte WRX80 SU8 IPMI is the main contender right now. This one does say in the manual that one of the 8pin aux is ATX 12V GPU power connector. I’m hopeful it means what I think it means.
The ASRock WRX80D8-2T is interesting because all the x16 slots look like full x16 as per the spec page and manual. But those OcuLink connectors I never seen used for storage an I’d rather not buy cables for it. And I have no use for 12 SATA ports.
The Gigabyte officially only supports 3000WX series. There’s a BIOS that does support it, but it’s not the latest - they decided to yank the support for the CPU for some unknown reason(?)
I need Gigabyte wrx80-su8-ipmi f5 bios BIOS can be found here however.
Also their latest bios is from 2023… Asrock has had two updates recently in 2025. They’ve also sent me custom BIOSes with CPPC/Power Supply Idle Control when I asked for them.
The server boards probably don’t have as beefy VRM (heatsinks) or they expect high airflow, compared to desktop/workstation boards.
That is interesting.
I ended up ordering the ASRock WRX80 Creator, by the simple virtue of it being available new locally and cheaper than used Chinese eBay stuff I’d have to wait weeks for and eventually pay even more at the border.
Did you buy a CPU yet? I just bought myself a 5975WX and the 5955WX will be available soon™. Targeted marketing :wink:
Be careful when buying the CPU, I have just got all the parts for a 5000pro system and after a full weekend of troubleshooting the various second hand parts, I think I have an OEM locked processor.
I got 256gb ECC before the prices got too crazy and the asrock creator board + noctua cooler only cost me £350, got various nvme and 3.5"s for decent prices as well so I can’t not get a new processor now :grimacing:
True, some sellers might not mention or even know about it. My 5955WX is definitely unlocked though.
Thanks!
Actually I got both the motherboard and the cpu brand new. For some reason the 5955WX got a significant price drop at a local store. And as you say, who knows what people are selling used and claimed as unlocked, and not even that much cheaper than the deal I found. With this I’m guaranteed a new product and with warranty.
I managed to get a 5955wx refurb at a decent price that is coming tomorrow, that way I can be positive if it is indeed my CPU or perhaps my bargain motherboard. The CPU came from cex and the motherboard was b listed on a reputable web store in the UK so my hopes on the CPU are not high :sweat_smile:
If it is the CPU then perhaps I could return this test unit and purchase yours if it’s still available and at a better price
The creator is a nice board it’s good you will have warranty , I think if I keep my eyes out I can pick up one of these random discounts on 3000/5000 parts then just sell the current CPU on eBay ( the non locked backup that is)
What’d you pay for the 5955WX?
£640 for 5955wx from box as a refurb unit with a year warranty, the 5995wx cost me about £1200 - should not be too difficult to get that returned to cex hopefully
PSA for the Asrock WRX80 Creator R2.0
When installing a new CPU, the BIOS will reset to defaults. The default setting for “Onboard VGA” is “Auto”, and in the presence of a dGPU, it’ll actually be disabled.
I thought my new 5975WX was defective and I re-seated it once, but I still kept getting error_10 bios_post_progress in the WebKVM (or code 42 on the debug lcd on the motherboard). Very frustrated!
Until I got a hunch, from a previous motherboard not POSTing without a monitor attached (or a HDMI dummy plug)… I plugged in a monitor and et voilà - instantly POSTed. I have a GTX 1660 in the server purely for Plex transcoding purposes.
Essentially makes the BMC/WebKVM useless. But it is a workstation motherboard after all I guess.
EDIT: the no-POST is actually (partly) a fault of the GTX 1660. That’s where my earlier hunch was from, my previous server(B550 platform, no iGPU) with that very same GPU wouldn’t POST without a dummy plug.
I used to have an additional RX6400 in the WRX80 (VM passthrough) and with that, it would POST even without a monitor connected, BUT the earlier problem (no picture in WebKVM) was still present.
I still don’t understand why Asrock can’t make the onboard VGA enabled by default, since in my testing, the BIOS POSTs to both the dGPU and the BMC VGA with it enabled. Seems like a sane default setting to me, shouldn’t hinder workstation/desktop users in any way? And actually makes the BMC usable!
