Hello all!
I recently built this workstation for a small repair shop environment, and to optimize it I’m wondering if any of you guys could give me pointers on usage of VMs with physical storage.
Given that I’m a complete noob when it comes to virtual machines, I had assumed that I would be able to allocate two SATA drives to one VM and two to another in order to run multiple operations (HDD>SSD clones, file transfers) at the same time. However, achieving that goal has proven to be very complicated and I haven’t yet been able to get it to work. I’ve been trying to use Virtualbox for this, and I can’t get drive access permissions to allow loading of physical disks through .vmdk files which target their positions in the drive order.
I’m open to trying new methods, including going through VMWare or Windows Hyper-V instead, but ultimately I need to be able to distribute physical storage to desired VMs with tolerance to change in drive IDs as I swap out to drives from different customers. I wouldn’t really mind if I had to run command batches for this.
I have more questions, most notably on file access god mode and the use of WIMs in virtual machines, but I will save those for later. Any help on the above would be greatly appreciated.
