Phantek Enthoo Primo | Tek Syndicate
				</p>
Long overdue is our review of the Phanteks Enthoo Primo! This case is a behemoth.
If you have a big case fetish, this case is for you. It's ample without being huge for no reason. If you are looking for a full tower that isn't unwieldy or a tower case that can easily support a no-compromises open loop liquid cooling setup, then this case is the one you've been looking for.
There are also a ton of gnarly and wicked case builds all around the internet with this case. Overclock.net has a ton of interesting builds. Check it out:
https://www.google.com/#q=enthoo+primo+build+log
This is a companion discussion topic for the original entry at https://teksyndicate.com/videos/phantek-enthoo-primo
Nice to see that you are getting around to taking a look at Phanteks' gear. I wish I had Primo and could post my build log but if you ever do a review of the Enthoo Pro/Luxe I'll be sure to show off my log then
you guys really should take a look at the matx enthoo evolv. I have one and am interested to hear teksyndicate's opinion.
I don't have a big case fetish, but i do have a fetish for cases with exceedingly great build quality that have dust filters everywhere and are properly dust-proof. Cases that also manage to have a very functional interior that's been well thought out.
If i had more dosh to dish out on a particularly higher budget build, this would be my first and only choice.
Alas, for the time being i am going for the H440.
Great video Wendell, I used this case for my first custom loop build, it was really nice to work with and allowed me to use a 45mm thick 420mm raidiator in the top and a 60mm thick 280 in the bottom with no problems. Since taking the picture below I've managed to make up a graphics card support using one of the spare expansion slot covers so it now sits perfectly straight.
Ed.
Yep. Just found my next case...
This is a great build. Do you have a build log or more extensive set of pictures? Can you post a link?
Different case Wendell but it is a Phanteks case. I really love the Phanteks cases now when I got mine. Love how the whole case can be stripped since it is held together by screws rather then rivets.
Thanks! I've not got a build log but I'm sure I could get some better pics of it and send you a link.
Hello All here in my last build.... not done yet still making the cables. Alway use Corsaire till I gave this Phanteks case a try.... Its well built with endless ways to build in it and it's very mod friendly seeing how a lot of the case is put together with screws....
Case: Phanteks Enthoo Primo
Mother Board: Asus Hero VII
CPU: 4790K @ 4.4 GHZ
Memory: 32G Corsiar Dominator 2200
Vidio: 2 Asus GTX780 with EK FC waterblocks
Storage: 2 Samsung SSD 250Gm 500G
Cooling: CPU EK Evo waterblock, 2 Radiators 360 @ 40mm thick 280 @ 60mm thick. Primochill fittings and tubing. EK 270 rez and D5 pump. Both rads are in puch pull with corsair fans.
PSU: Corsair 1200
Not as tidy as some of the others, and I ran out of white tubing when I moved my reservoir (it's on order), but I'm still fairly happy with it, for now.
System Specs:
CPU: i7 2600K
Mothership: MSI Z77A-GD55
RAM: 16GB Corsair Vengeance
GPU: SLI GTX 780ti
PSU: Corsair RM850
Cables: Silverstone extensions
Watercooling Specs:
Radiator 1: Alphacool Monsta 240x80mm
Radiator 2: Alphacool XT45 480x45mm
Pump: Alphacool D5
Reservoir: PrimoChill CTR Phase II
CPU Block: Alphacool NexXxos XP2 Light
GPU Blocks: Alphacool NexXxos GPX
Tubing: PrimoChill Primoflex
Fittings: Various Aphacool Deep Black
Fans: EK Vardar
