Hello, hoping somebody can enlighten me on this one since I’m a newbie to pFsense. The problem I’m having are the following:
when I create a rule to limit the bandwidth of a pool of IPs in an Alias, it loses internet connection
when I block the internet connection for a pool of IPs in an Alias, it loses internet connection as well
Other things to know is that the IPs of the devices are statically assigned under DHCP and the tick box for “Create an ARP Table Static Entry for this MAC & IP Address pair.” is checked.
Are you referring to the ‘Block Internet Use’ section? If so, the destination is your problem. You’re telling it to block everything not destined for your WAN adapter’s subnet (that doesn’t mean internet) which is probably breaking routing and other services running on pfSense (DNS?). If the lab or student devices only need access to other devices on 192.168.10.0/24 then it should be ! LAN net. But double check your routes and also verify they don’t need access to OPT2 and CAPTIVEPORTAL first.
