I have a WAN connection which seems to change it’s IP once a day and most of the time when this happens that interface in pfsense goes down and won’t come back up until I manually release and renew the DHCP lease.
Does anyone have any ideas on what I can try to get this to work more reliably?
You can install Service Watchdog in the package manager to automatically restart DHCP service when it stops working and many others. Hopefully it will renew DHCP lease after restart.
I think dhcpd is the DHCP server not the client, besides the service is running. The gateway monitor service should restart interfaces when they go down but for some reason the DHCP isn’t working correctly unless I renew it manually. It probably some issue with too long of a lease time or some other DHCP option but I don’t see anywhere obvious to change that without messing with the config files,whichnid like to avoid doing.
