I have currently 3GB of RAM allocated to a pfSense VM. Even with 3GB it never fills more than 15% with /var and /tmp both residing in Ram. It is a near freshly installed pfSense in a VM on my unRaid server. I migrated from a separate machine since it didn’t support AESNI and I would like to save on power anyway. So I have been noticing there is some HUGE CPU usage going on. Sometimes it literally maxes out the two cores I gave pfSense entirely and causes up to a 60% drop in internet speed for as long as it is happening. usually, after a few minutes, it settles down to normal CPU usage, idling at a max of 1%-2% and barely kissing 5% with heavy usage.
Firstly, could it be related to running pfSense in a VM? I know a few guys that are very successfully running pfSense on unRaid through a VM for everyday use and it works great for them.
Secondly, I did actually make a complete screw up and I borked my pfSense a few days after I installed it on this VM. Thankfully, I had a backup of the configuration on hand so i was very quickly able to reinstall onto a fresh instance and restore. I honestly don’t know if this issue was present before but it may have been and I didn’t notice it. I say this because I only realized it was an issue when it was eating all the CPU cycles from my Plex docker making transcoding not work at all.
I went and did some digging and found that I am not the only one to have had this issue and so I turned on SSH and ran a few commands outlined there and this is what I have found. Seems that every time this happens it is this specific process. /usr/local/bin/php-cgi -f /usr/local/sbin/prefixes.php It can easily hit 99% CPU usage. From what I can tell, some posts were saying it has to do with DHCP6. I can’t disable IPv6 entirely since my wife works from home and some of the services her work uses are IPv6 only. Though, frankly, I shouldn’t have to disable IPv6 to fix this. I have never had this problem before and just need a hand figuring out what the heck I can do to stop this insane CPU thrashing. Maybe some script is stuck in a loop? I simply am not skilled enough here to have any idea.
My motherboard is fully capable of virtualization. I passed through a physical 4 port Intel gigabit NIC. WAN, LAN, ROOMMATELAN, and the fourth is a spare I currently don’t have hooked up anywhere. For storage, I am not using the virtio drivers and am fully emulating the storage. I did this because even though I am fully aware pfSense has virtio support in the kernel, on unRaid you still have to do the initial install emulating a standard SATA interface and since I had to reinstall it due to my own screw up, it has remained in SATA mode.
Since it is virtualized, would the VMtools package be useful for me? I thought that was only for VMware products but honestly, I have no idea. Could it have something to do with my virtualization setup or settings? It is entirely possible I am not doing it the ‘best’ way.
Sorry for the wall but I figured too much info is likely better than not enough. I just don’t know what is going to be useful and what is not.
Thanks for any assistance you can provide in advance!
