I have a dual port NIC and I want to assign a LAN on each port. I have assigned 192.168.1.0/25 to LAN and 192.168.1.128/25 to OPT1.
Here is what I have donme so far: configured WAP to subnet, allow traffic through firewall and configured DHCP server. I want to isolate LAN and OPT1, which will be a wireless network.
OPT1 does not connect to the internet, and this is my problem. If there is another way to accomplish this in a more efficient way, please let me know.
excuse, it’s 6 30 in the morning so i might no have read it correctly, but … you need help about what ? the full pf sense dual configuration ? or you have an issue somewhere ?
Did you configure NAT for the second OPT network to be NATed on its way out to the internet?
Second the notion to just use /24 networks unless you have some specific reason not to, using /24s everywhere just makes things so much simpler and less confusing - and in most cases it’s not like you’ve got a shortage of RFC 1918 private network addresses.
You need to disable those first two rules, from the interface options. If you block private networks on a private network you’re going to block all traffic.
