Pfsense Crashing randomly after 2 days
Hello everybody,
So i have 2 of these boxes (1 home and 1 at the office) :- Intel 11th GEN N5105 Mini PC with 4x 2.5G Intel i226LAN
Both running identical pfsesnse ce 2.7.2 under proxmox ve 8.14 configured with 16GB of RAM. I have a WireGuard connection between the 2 sites using pfsesne WireGuard package. Additionally, I am also running pfblockerng-devel from pfsense’s package manager on both sites. I have configured NIC hardware passthrough on both proxmox boxes (home and office) for pfsense WAN and LAN on both sites.
Both pfsense install have 2 cores and 8GB of RAM dedicated to them. So the configs are identical
One of my boxes keeps crashing randomly after 2-3 days, while the other box is rock stable for a month.
The box that crashes gives me the following crash dump.
Crash report begins.  Anonymous machine information:
amd64
14.0-CURRENT
FreeBSD 14.0-CURRENT amd64 1400094 #1 RELENG_2_7_2-n255948-8d2b56da39c: Wed Dec  6 20:45:47 UTC 2023     root@freebsd:/var/jenkins/workspace/pfSense-CE-snapshots-2_7_2-main/obj/amd64/StdASW5b/var/jenkins/workspace/pfSense-CE-snapshots-2_7_2-main/sources/F
Crash report details:
No PHP errors found.
Filename: /var/crash/info.0
Dump header from device: /dev/da0p3
  Architecture: amd64
  Architecture Version: 4
  Dump Length: 76800
  Blocksize: 512
  Compression: none
  Dumptime: 2024-03-31 11:11:24 +0530
  Hostname: home-pfSense.home.io
  Magic: FreeBSD Text Dump
  Version String: FreeBSD 14.0-CURRENT amd64 1400094 #1 RELENG_2_7_2-n255948-8d2b56da39c: Wed Dec  6 20:45:47 UTC 2023
  Panic String: double fault
  Dump Parity: 3857874015
  Bounds: 0
  Dump Status: good
Filename: /var/crash/textdump.tar.0
ddb.txt���������������������������������������������������������������������������������������������0600����0�������0�������140000������14602173604�  7075� �����������������������������������������������������������������������������������������������������ustar���root����������������������������wheel������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������db:0:kdb.enter.default>  show registers
cs                        0x20
ds                        0x3b
es                        0x3b
fs                        0x13
gs                        0x1b
ss                        0x28
rax                       0x12
rcx         0xffffffff81451bc8
rdx         0xffffffff831031a0  dblfault_stack+0x910
rbx                        0x4
rsp         0xffffffff83103560  dblfault_stack+0xcd0
rbp         0xffffffff83103560  dblfault_stack+0xcd0
rsi                       0x19
rdi         0xffffffff82d3f3d8  vt_conswindow+0x10
r8                           0
r9                           0
r10                          0
r11                          0
r12                        0x1
r13                       0x3b
r14         0xffffffff813a43cc
r15         0xfffffe00a7700e40
rip         0xffffffff80d32342  kdb_enter+0x32
rflags                    0x86
kdb_enter+0x32: movq    $0,0x234a4c3(%rip)
db:0:kdb.enter.default>  run lockinfo
db:1:lockinfo> show locks
No such command; use "help" to list available commands
db:1:lockinfo>  show alllocks
db:1:lockinfo>  show lockedvnods
Locked vnodes
db:0:kdb.enter.default>  show pcpu
cpuid        = 0
dynamic pcpu = 0x1123f80
curthread    = 0xfffffe00a7700e40: pid 0 tid 100788 critnest 1 "wg_tqg_0"
curpcb       = 0xfffffe00a7701360
fpcurthread  = none
idlethread   = 0xfffffe0011ed83a0: tid 100003 "idle: cpu0"
self         = 0xffffffff84010000
curpmap      = 0xffffffff83020ab0
tssp         = 0xffffffff84010384
rsp0         = 0xfffffe00a8d39000
kcr3         = 0x76932000
ucr3         = 0xffffffffffffffff
scr3         = 0x76932000
gs32p        = 0xffffffff84010404
ldt          = 0xffffffff84010444
tss          = 0xffffffff84010434
curvnet      = 0
db:0:kdb.enter.default>  bt
Tracing pid 0 tid 100788 td 0xfffffe00a7700e40
kdb_enter() at kdb_enter+0x32/frame 0xffffffff83103560
vpanic() at vpanic+0x163/frame 0xffffffff83103690
panic() at panic+0x43/frame 0xffffffff831036f0
dblfault_handler() at dblfault_handler+0x1ce/frame 0xffffffff831037b0
Xdblfault() at Xdblfault+0xd7/frame 0xffffffff831037b0
--- trap 0x17, rip = 0xffffffff8126af94, rsp = 0xffffffff83103850, rbp = 0xfffffe00a8d38e40 ---
Xdblfault() at Xdblfault+0x4/frame 0xfffffe00a8d38e40
gtaskqueue_run_locked() at gtaskqueue_run_locked+0x14e/frame 0xfffffe00a8d38ec0
gtaskqueue_thread_loop() at gtaskqueue_thread_loop+0xc2/frame 0xfffffe00a8d38ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00a8d38f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00a8d38f30
--- trap 0, rip = 0, rsp = 0, rbp = 0 ---
db:0:kdb.enter.default>  ps
  pid  ppid  pgrp   uid  state   wmesg   wchan               cmd
11472 64390    22     0  S       nanslp  0xffffffff83063d61  sleep
55253 55196 54266     0  S       piperd  0xfffffe00a65dbe38  sh
55196 54266 54266     0  S       wait    0xfffffe00a77095a0  sh
55192 54266 54266     0  S       (threaded)                  sshg-blocker
100787                   S       piperd  0xfffffe00a65d92d8  sshg-blocker
126480                   S       nanslp  0xffffffff83063d60  sshg-blocker
54869 54266 54266     0  S       piperd  0xfffffe00a7112e38  sshg-parser
54617 54266 54266     0  S       piperd  0xfffffe00a65dac70  cat
54266 88941 54266     0  Ss      wait    0xfffffe00a7707560  sh
 6512  6359  5051     0  S       nanslp  0xffffffff83063d60  sleep
 6359     1  5051     0  S       wait    0xfffffe00a7ca5b00  sh
13944   398   398     0  S       accept  0xfffff80017181590  php-fpm
55768   398   398     0  S       (threaded)                  php-fpm
100229                   S       accept  0xfffff80017181590  php-fpm
46086   398   398     0  S       accept  0xfffff80017181590  php-fpm
77585     1 77585    59  Ss      (threaded)                  unbound
100770                   S       kqread  0xfffff8010a3f1c00  unbound
126509                   S       kqread  0xfffff8010a3f1900  unbound
 9256     1  9256   136  Ss      select  0xfffff8010abb50c0  dhcpd
49605     1 49605     0  Ss      kqread  0xfffff8006e748900  dhcpleases
 2768     1  2768     0  Ss      (threaded)                  dpinger
100781                   S       uwait   0xfffff801f554f800  dpinger
115765                   S       sbwait  0xfffff8010aa241cc  dpinger
115766                   S       nanslp  0xffffffff83063d60  dpinger
115767                   S       nanslp  0xffffffff83063d60  dpinger
115768                   S       accept  0xfffff8010adb3d10  dpinger
 2170     1  2170     0  Ss      (threaded)                  dpinger
101605                   S       uwait   0xfffff8006ea25280  dpinger
115761                   S       sbwait  0xfffff801f55bc1cc  dpinger
115762                   S       nanslp  0xffffffff83063d60  dpinger
115763                   S       nanslp  0xffffffff83063d61  dpinger
115764                   S       accept  0xfffff8001706e950  dpinger
31012   398   398     0  S       accept  0xfffff80017181590  php-fpm
73835     1 17089     0  S       select  0xfffff801f576eec0  tail_pfb
72280     1 17089     0  S       piperd  0xfffffe00a65dcc70  php_pfb
72060     1 17089     0  S       kqread  0xfffff801f55ddd00  tail_pfb
67765 62906 67765     0  S+      ttyin   0xfffff800079548b0  sh
62906 60665 62906     0  S+      wait    0xfffffe00857a1580  sh
61694     1 61694     0  Ss+     ttyin   0xfffff800079570b0  getty
61576     1 61576     0  Ss+     ttyin   0xfffff800079578b0  getty
61381     1 61381     0  Ss+     ttyin   0xfffff800079560b0  getty
61056     1 61056     0  Ss+     ttyin   0xfffff800079568b0  getty
60816     1 60816     0  Ss+     ttyin   0xfffff800079550b0  getty
60756     1 60756     0  Ss+     ttyin   0xfffff800079558b0  getty
60694     1 60694     0  Ss+     ttyin   0xfffff800079540b0  getty
60665     1 60665     0  Ss+     wait    0xfffffe0011fcdac0  login
37384     1 37384     0  Ss      nanslp  0xffffffff83063d61  php_wg
69291     1 68981     0  S       kqread  0xfffff8006e655d00  lighttpd_pfb
93349 93128 93128     0  S       nanslp  0xffffffff83063d60  minicron
93128     1 93128     0  Ss      wait    0xfffffe00a6d4b5a0  minicron
93106 92730 92730     0  S       nanslp  0xffffffff83063d61  minicron
92730     1 92730     0  Ss      wait    0xfffffe00a6d4a580  minicron
92395 91810 91810     0  S       nanslp  0xffffffff83063d60  minicron
91810     1 91810     0  Ss      wait    0xfffffe00a788a020  minicron
91506 91364 91364     0  S       nanslp  0xffffffff83063d61  minicron
91364     1 91364     0  Ss      wait    0xfffffe00a6ca95a0  minicron
88941     1 88941     0  Ss      select  0xfffff80007aebec0  syslogd
64390     1    22     0  S+      wait    0xfffffe00a788b040  sh
17591     1 17591     0  Ss      select  0xfffff800184a58c0  radvd
 9564  9195  9195     0  S       kqread  0xfffff80068ebcd00  nginx
 9462  9195  9195     0  S       kqread  0xfffff80068ebbe00  nginx
 9195     1  9195     0  Ss      pause   0xfffffe0011ed4bb0  nginx
97647     1 97647     0  Ss      (threaded)                  ntpd
100331                   S       select  0xfffff801f5348840  ntpd
22198     1 22198     0  Ss      nanslp  0xffffffff83063d60  cron
15332     1 15332     0  Ss      bpf     0xfffff8006ed14800  filterlog
  601     1   601     0  Ss      select  0xfffff8006e442440  devd
  441   439   439     0  S       kqread  0xfffff80017644000  check_reload_status
  439     1   439     0  Ss      kqread  0xfffff800056eb400  check_reload_status
  398     1   398     0  Ss      kqread  0xfffff80048175400  php-fpm
   21     0     0     0  DL      aldslp  0xffffffff83020d58  [ALQ Daemon]
   20     0     0     0  DL      syncer  0xffffffff8309dba8  [syncer]
   19     0     0     0  DL      vlruwt  0xfffffe00857a3060  [vnlru]
   18     0     0     0  DL      (threaded)                  [bufdaemon]
100145                   D       psleep  0xffffffff8309cbb0  [bufdaemon]
100151                   D       -       0xffffffff82c03100  [bufspacedaemon-0]
100152                   D       -       0xffffffff82c03380  [bufspacedaemon-1]
100153                   D       -       0xffffffff82c03600  [bufspacedaemon-2]
100154                   D       -       0xffffffff82c03880  [bufspacedaemon-3]
   17     0     0     0  DL      psleep  0xffffffff830f4050  [vmdaemon]
    9     0     0     0  DL      (threaded)                  [pagedaemon]
100143                   D       psleep  0xffffffff830dc4b8  [dom0]
100149                   D       launds  0xffffffff830dc4c4  [laundry: dom0]
100150                   D       umarcl  0xffffffff811372a0  [uma]
    8     0     0     0  DL      -       0xffffffff82e77708  [rand_harvestq]
    7     0     0     0  DL      pftm    0xffffffff80fa33c0  [pf purge]
    6     0     0     0  DL      (threaded)                  [zfskern]
100108                   D       t->zthr 0xfffff800027b5248  [arc_evict]
100109                   D       t->zthr 0xfffff800027b5048  [arc_reap]
100110                   D       -       0xfffff800027b6d00  [dbu_evict]
100111                   D       dbuf_ev 0xffffffff838f7f28  [dbuf_evict_thread]
100112                   D       -       0xfffff800027b6800  [z_vdev_file_0]
100113                   D       -       0xfffff800027b6800  [z_vdev_file_1]
100114                   D       -       0xfffff800027b6800  [z_vdev_file_2]
100115                   D       -       0xfffff800027b6800  [z_vdev_file_3]
100116                   D       -       0xfffff800027b6800  [z_vdev_file_4]
100117                   D       -       0xfffff800027b6800  [z_vdev_file_5]
100118                   D       -       0xfffff800027b6800  [z_vdev_file_6]
100119                   D       -       0xfffff800027b6800  [z_vdev_file_7]
100120                   D       -       0xfffff800027b6800  [z_vdev_file_8]
100121                   D       -       0xfffff800027b6800  [z_vdev_file_9]
100122                   D       -       0xfffff800027b6800  [z_vdev_file_10]
100123                   D       -       0xfffff800027b6800  [z_vdev_file_11]
100124                   D       -       0xfffff800027b6800  [z_vdev_file_12]
100125                   D       -       0xfffff800027b6800  [z_vdev_file_13]
100126                   D       -       0xfffff800027b6800  [z_vdev_file_14]
100127                   D       -       0xfffff800027b6800  [z_vdev_file_15]
100128                   D       l2arc_f 0xffffffff838f7428  [l2arc_feed_thread]
100129                   D       -       0xfffff800027b7500  [zfsvfs]
100130                   S       zevent_ 0xffffffff838f84c8  [sysevent]
100189                   D       -       0xfffff800056d4400  [z_zvol]
100190                   D       -       0xfffff800056d4200  [z_prefetch_0]
100191                   D       -       0xfffff800056d4200  [z_prefetch_1]
100192                   D       -       0xfffff800056d5e00  [z_upgrade_0]
100193                   D       -       0xfffff800056d5e00  [z_upgrade_1]
100196                   D       -       0xfffff800056d2700  [dp_sync_taskq]
100197                   D       -       0xfffff800056d5b00  [dp_zil_clean_taskq_]
100198                   D       -       0xfffff800056d5b00  [dp_zil_clean_taskq_]
100199                   D       -       0xfffff800056d5300  [z_zrele_0]
100200                   D       -       0xfffff800056d5300  [z_zrele_1]
100201                   D       -       0xfffff800056d5000  [z_unlinked_drain_0]
100202                   D       -       0xfffff800056d5000  [z_unlinked_drain_1]
100206                   D       -       0xfffff800056d2b00  [metaslab_group_task]
100207                   D       -       0xfffff80007a83600  [metaslab_group_task]
100220                   D       tx->tx_ 0xfffff800029aad50  [txg_thread_enter]
100221                   D       tx->tx_ 0xfffff800029aad30  [txg_thread_enter]
100222                   D       mmp->mm 0xfffffe0094de4478  [mmp_thread_enter]
100223                   D       t->zthr 0xfffff80007a86c48  [z_indirect_condense]
100224                   D       t->zthr 0xfffff80007b5c248  [z_livelist_destroy]
100225                   D       t->zthr 0xfffff80007a85348  [z_livelist_condense]
100226                   D       t->zthr 0xfffff80007b5c348  [z_checkpoint_discar]
100227                   D       vd->vde 0xfffffe0094f4edd8  [vdev_autotrim_threa]
    5     0     0     0  DL      -       0xffffffff830fdd18  [busdma]
   16     0     0     0  DL      (threaded)                  [usb]
100049                   D       -       0xfffffe008560edc8  [usbus0]
100050                   D       -       0xfffffe008560ee20  [usbus0]
100051                   D       -       0xfffffe008560ee78  [usbus0]
100052                   D       -       0xfffffe008560eed0  [usbus0]
100053                   D       -       0xfffffe008560ef28  [usbus0]
100055                   D       -       0xfffffe00857acdc8  [usbus1]
100056                   D       -       0xfffffe00857ace20  [usbus1]
100057                   D       -       0xfffffe00857ace78  [usbus1]
100058                   D       -       0xfffffe00857aced0  [usbus1]
100059                   D       -       0xfffffe00857acf28  [usbus1]
100061                   D       -       0xfffffe0085942dc8  [usbus2]
100062                   D       -       0xfffffe0085942e20  [usbus2]
100063                   D       -       0xfffffe0085942e78  [usbus2]
100064                   D       -       0xfffffe0085942ed0  [usbus2]
100065                   D       -       0xfffffe0085942f28  [usbus2]
100067                   D       -       0xfffffe0085addcf0  [usbus3]
100068                   D       -       0xfffffe0085addd48  [usbus3]
100069                   D       -       0xfffffe0085addda0  [usbus3]
100070                   D       -       0xfffffe0085adddf8  [usbus3]
100071                   D       -       0xfffffe0085adde50  [usbus3]
100073                   D       -       0xfffffe008e470dc8  [usbus4]
100074                   D       -       0xfffffe008e470e20  [usbus4]
100075                   D       -       0xfffffe008e470e78  [usbus4]
100076                   D       -       0xfffffe008e470ed0  [usbus4]
100077                   D       -       0xfffffe008e470f28  [usbus4]
100078                   D       -       0xfffffe008e615dc8  [usbus5]
100079                   D       -       0xfffffe008e615e20  [usbus5]
100080                   D       -       0xfffffe008e615e78  [usbus5]
100081                   D       -       0xfffffe008e615ed0  [usbus5]
100082                   D       -       0xfffffe008e615f28  [usbus5]
100083                   D       -       0xfffffe008e7abdc8  [usbus6]
100084                   D       -       0xfffffe008e7abe20  [usbus6]
100085                   D       -       0xfffffe008e7abe78  [usbus6]
100086                   D       -       0xfffffe008e7abed0  [usbus6]
100087                   D       -       0xfffffe008e7abf28  [usbus6]
100088                   D       -       0xfffffe008e941cf0  [usbus7]
100089                   D       -       0xfffffe008e941d48  [usbus7]
100090                   D       -       0xfffffe008e941da0  [usbus7]
100091                   D       -       0xfffffe008e941df8  [usbus7]
100092                   D       -       0xfffffe008e941e50  [usbus7]
    4     0     0     0  DL      (threaded)                  [cam]
100046                   D       -       0xffffffff82e28240  [doneq0]
100047                   D       -       0xffffffff82e281c0  [async]
100141                   D       -       0xffffffff82e28090  [scanner]
   15     0     0     0  DL      seqstat 0xfffff8000294ac88  [sequencer 00]
    3     0     0     0  DL      (threaded)                  [crypto]
100041                   D       crypto_ 0xffffffff830d9ac0  [crypto]
100042                   D       crypto_ 0xfffff800026a9230  [crypto returns 0]
100043                   D       crypto_ 0xfffff800026a9280  [crypto returns 1]
   14     0     0     0  DL      (threaded)                  [geom]
100036                   D       -       0xffffffff8301f738  [g_event]
100037                   D       -       0xffffffff8301f740  [g_up]
100038                   D       -       0xffffffff8301f748  [g_down]
   13     0     0     0  DL      (threaded)                  [ng_queue]
100033                   D       sleep   0xffffffff82d99380  [ng_queue0]
100034                   D       sleep   0xffffffff82d99380  [ng_queue1]
    2     0     0     0  WL      (threaded)                  [clock]
100031                   I                                   [clock (0)]
100032                   I                                   [clock (1)]
   12     0     0     0  WL      (threaded)                  [intr]
100015                   I                                   [swi5: fast taskq]
100019                   I                                   [swi6: task queue]
100020                   I                                   [swi6: Giant taskq]
100029                   I                                   [swi1: netisr 0]
100030                   I                                   [swi1: netisr 1]
100048                   I                                   [irq16: uhci0 uhci3+]
100054                   I                                   [irq17: uhci1 uhci4]
100060                   I                                   [irq18: uhci2 uhci5]
100066                   I                                   [irq19: ehci0 ehci1]
100072                   I                                   [irq24: hdac0]
100093                   I                                   [irq20: virtio_pci0]
100096                   I                                   [irq34: virtio_pci1]
100097                   I                                   [irq35: virtio_pci1]
100098                   I                                   [irq36: virtio_pci1]
100099                   I                                   [irq37: virtio_pci1]
100100                   I                                   [irq38: ahci0]
100101                   I                                   [irq1: atkbd0]
100102                   I                                   [irq12: psm0]
100133                   I                                   [swi1: pf send]
100134                   I                                   [swi1: pfsync]
   11     0     0     0  RL      (threaded)                  [idle]
100003                   CanRun                              [idle: cpu0]
100004                   Run     CPU 1                       [idle: cpu1]
    1     0     1     0  SLs     wait    0xfffffe0011ed4040  [init]
   10     0     0     0  DL      audit_w 0xffffffff830d9fa8  [audit]
    0     0     0     0  RLs     (threaded)                  [kernel]
100000                   D       swapin  0xffffffff8301fcd0  [swapper]
100005                   D       -       0xfffff800021e7100  [if_io_tqg_0]
100006                   D       -       0xfffff800021e6e00  [if_io_tqg_1]
100007                   D       -       0xfffff800021e6c00  [if_config_tqg_0]
100008                   D       -       0xfffff800021e6a00  [softirq_0]
100009                   D       -       0xfffff800021e6800  [softirq_1]
100010                   D       -       0xfffff800021e6600  [linuxkpi_irq_wq]
100011                   D       -       0xfffff800021e6400  [thread taskq]
100012                   D       -       0xfffff800021e6200  [aiod_kick taskq]
100013                   D       -       0xfffff800021e6000  [deferred_unmount ta]
100014                   D       -       0xfffff80002761200  [inm_free taskq]
100016                   D       -       0xfffff80002762c00  [in6m_free taskq]
100017                   D       -       0xfffff80002762a00  [kqueue_ctx taskq]
100018                   D       -       0xfffff80002762800  [pci_hp taskq]
100021                   D       -       0xfffff80002762000  [linuxkpi_short_wq_0]
100022                   D       -       0xfffff80002762000  [linuxkpi_short_wq_1]
100023                   D       -       0xfffff80002762000  [linuxkpi_short_wq_2]
100024                   D       -       0xfffff80002762000  [linuxkpi_short_wq_3]
100025                   D       -       0xfffff80002763a00  [linuxkpi_long_wq_0]
100026                   D       -       0xfffff80002763a00  [linuxkpi_long_wq_1]
100027                   D       -       0xfffff80002763a00  [linuxkpi_long_wq_2]
100028                   D       -       0xfffff80002763a00  [linuxkpi_long_wq_3]
100035                   D       -       0xfffff80002764900  [firmware taskq]
100039                   D       -       0xfffff800021ea200  [crypto_0]
100040                   D       -       0xfffff800021ea200  [crypto_1]
100044                   D       -       0xfffff800026aac00  [t4_rst_thr]
100094                   D       vtbslp  0xfffff800027e1580  [virtio_balloon]
100103                   D       -       0xfffff80003135500  [system_taskq_0]
100104                   D       -       0xfffff80003135500  [system_taskq_1]
100105                   D       -       0xfffff80003135200  [system_delay_taskq_]
100106                   D       -       0xfffff80003135200  [system_delay_taskq_]
100107                   D       -       0xfffff800027b5400  [arc_prune]
100131                   D       -       0xfffff80007833900  [ip_mroute_tskq task]
100135                   D       -       0xfffff80007959200  [acpi_task_0]
100136                   D       -       0xfffff80007959200  [acpi_task_1]
100137                   D       -       0xfffff80007959200  [acpi_task_2]
100139                   D       -       0xfffff800021e9300  [mca taskq]
100140                   D       -       0xfffff800026aa100  [CAM taskq]
100142                   D       -       0xfffff8000795bd00  [mlx4]
100155                   D       -       0xfffff800056e9400  [z_null_iss]
100156                   D       -       0xfffff80007a83900  [z_null_int]
100157                   D       -       0xfffff800056e9900  [z_rd_iss_0]
100158                   D       -       0xfffff800056e9900  [z_rd_iss_1]
100159                   D       -       0xfffff800056e9900  [z_rd_iss_2]
100160                   D       -       0xfffff800056e9900  [z_rd_iss_3]
100161                   D       -       0xfffff800056e9900  [z_rd_iss_4]
100162                   D       -       0xfffff800056e9900  [z_rd_iss_5]
100163                   D       -       0xfffff800056e9900  [z_rd_iss_6]
100164                   D       -       0xfffff800056e9900  [z_rd_iss_7]
100165                   D       -       0xfffff800056e9700  [z_rd_int]
100166                   D       -       0xfffff800056ea300  [z_wr_iss]
100167                   D       -       0xfffff800056ea600  [z_wr_iss_h_0]
100168                   D       -       0xfffff800056ea600  [z_wr_iss_h_1]
100169                   D       -       0xfffff800056ea600  [z_wr_iss_h_2]
100170                   D       -       0xfffff800056ea600  [z_wr_iss_h_3]
100171                   D       -       0xfffff800056ea600  [z_wr_iss_h_4]
100172                   D       -       0xfffff800056d2100  [z_wr_int]
100173                   D       -       0xfffff800056d3e00  [z_wr_int_h_0]
100174                   D       -       0xfffff800056d3e00  [z_wr_int_h_1]
100175                   D       -       0xfffff800056d3e00  [z_wr_int_h_2]
100176                   D       -       0xfffff800056d3e00  [z_wr_int_h_3]
100177                   D       -       0xfffff800056d3e00  [z_wr_int_h_4]
100178                   D       -       0xfffff800056d3800  [z_fr_iss]
100179                   D       -       0xfffff800056d3600  [z_fr_int]
100180                   D       -       0xfffff800056d3400  [z_cl_iss]
100181                   D       -       0xfffff800056d3200  [z_cl_int]
100182                   D       -       0xfffff800056d3000  [z_ioctl_iss]
100183                   D       -       0xfffff800056d4d00  [z_ioctl_int]
100184                   D       -       0xfffff800056d4b00  [z_trim_iss_0]
100185                   D       -       0xfffff800056d4b00  [z_trim_iss_1]
100186                   D       -       0xfffff800056d4b00  [z_trim_iss_2]
100187                   D       -       0xfffff800056d4b00  [z_trim_iss_3]
100188                   D       -       0xfffff800056d4600  [z_trim_int]
100259                   D       -       0xfffff80069bfa400  [wg_tqg_0]
100260                   D       -       0xfffff80017644b00  [wg_tqg_1]
100316                   D       -       0xfffff8006e657300  [dummynet]
100788                   Run     CPU 0                       [wg_tqg_0]
100789                   D       -       0xfffff801f5e03500  [wg_tqg_1]
db:0:kdb.enter.default>  alltrace
Tracing command kernel pid 0 tid 100000 td 0xffffffff83020240
sched_switch() at sched_switch+0x88a/frame 0xffffffff83f1fe70
mi_switch() at mi_switch+0xbb/frame 0xffffffff83f1fe90
sleepq_timedwait() at sleepq_timedwait+0x2f/frame 0xffffffff83f1fed0
_sleep() at _sleep+0x1d0/frame 0xffffffff83f1ff50
swapper() at swapper+0x69/frame 0xffffffff83f1ffa0
mi_startup() at mi_startup+0x30c/frame 0xffffffff83f1fff0
btext() at btext+0x23
Tracing command kernel pid 0 tid 100005 td 0xfffffe0011ed7560
sched_switch() at sched_switch+0x88a/frame 0xfffffe00107ace50
mi_switch() at mi_switch+0xbb/frame 0xfffffe00107ace70
msleep_spin_sbt() at msleep_spin_sbt+0x186/frame 0xfffffe00107acec0
gtaskqueue_thread_loop() at gtaskqueue_thread_loop+0xf1/frame 0xfffffe00107acef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00107acf30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00107acf30
--- trap 0x65006d, rip = 0x53006900000074, rsp = 0x73006e00440000, rbp = 0x61006400720049 ---
Tracing command kernel pid 0 tid 100006 td 0xfffffe0011ed6e40
sched_switch() at sched_switch+0x88a/frame 0xfffffe00107a7e50
mi_switch() at mi_switch+0xbb/frame 0xfffffe00107a7e70
msleep_spin_sbt() at msleep_spin_sbt+0x186/frame 0xfffffe00107a7ec0
gtaskqueue_thread_loop() at gtaskqueue_thread_loop+0xf1/frame 0xfffffe00107a7ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00107a7f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00107a7f30
--- trap 0x5f5e5b28, rip = 0x84ffffda1ee8d989, rsp = 0x8d4affffda65e8c4, rbp = 0xc3c031fffffe6be9 ---
Tracing command kernel pid 0 tid 100007 td 0xfffffe0011ed6720
sched_switch() at sched_switch+0x88a/frame 0xfffffe00107a2e50
mi_switch() at mi_switch+0xbb/frame 0xfffffe00107a2e70
msleep_spin_sbt() at msleep_spin_sbt+0x186/frame 0xfffffe00107a2ec0
gtaskqueue_thread_loop() at gtaskqueue_thread_loop+0xf1/frame 0xfffffe00107a2ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00107a2f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00107a2f30
--- trap 0xafafafaf, rip = 0xafafafafafafafaf, rsp = 0xafafafafafafafaf, rbp = 0xafafafafafafafaf ---
Tracing command kernel pid 0 tid 100008 td 0xfffffe0011ed6000
sched_switch() at sched_switch+0x88a/frame 0xfffffe001079de50
mi_switch() at mi_switch+0xbb/frame 0xfffffe001079de70
msleep_spin_sbt() at msleep_spin_sbt+0x186/frame 0xfffffe001079dec0
gtaskqueue_thread_loop() at gtaskqueue_thread_loop+0xf1/frame 0xfffffe001079def0
fork_exit() at fork_exit+0x7f/frame 0xfffffe001079df30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe001079df30
Tracing command kernel pid 0 tid 100009 td 0xfffffe0011f6ac80
sched_switch() at sched_switch+0x88a/frame 0xfffffe0010798e50
mi_switch() at mi_switch+0xbb/frame 0xfffffe0010798e70
msleep_spin_sbt() at msleep_spin_sbt+0x186/frame 0xfffffe0010798ec0
gtaskqueue_thread_loop() at gtaskqueue_thread_loop+0xf1/frame 0xfffffe0010798ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe0010798f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe0010798f30
--- trap 0x38c840f, rip = 0xffc8014881046348, rsp = 0xc7580e380d98948, rbp = 0x894dfe894c03ebc6 ---
Tracing command kernel pid 0 tid 100010 td 0xfffffe0011f6a560
sched_switch() at sched_switch+0x88a/frame 0xfffffe0010793e50
mi_switch() at mi_switch+0xbb/frame 0xfffffe0010793e70
msleep_spin_sbt() at msleep_spin_sbt+0x186/frame 0xfffffe0010793ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xf1/frame 0xfffffe0010793ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe0010793f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe0010793f30
--- trap 0xb0f05, rip = 0x11890ff3474, rsp = 0x8b4800000757880f, rbp = 0x20244c894800000a ---
Tracing command kernel pid 0 tid 100011 td 0xfffffe0011f69e40
sched_switch() at sched_switch+0x88a/frame 0xfffffe001078ee20
mi_switch() at mi_switch+0xbb/frame 0xfffffe001078ee40
_sleep() at _sleep+0x1f0/frame 0xfffffe001078eec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe001078eef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe001078ef30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe001078ef30
--- trap 0x8e, rip = 0x4be49d231f089, rsp = 0xee834918438b4859, rbp = 0x7b800000008890ff ---
Tracing command kernel pid 0 tid 100012 td 0xfffffe0011f69720
sched_switch() at sched_switch+0x88a/frame 0xfffffe0010789e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe0010789e40
_sleep() at _sleep+0x1f0/frame 0xfffffe0010789ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe0010789ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe0010789f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe0010789f30
Tracing command kernel pid 0 tid 100013 td 0xfffffe0011f69000
sched_switch() at sched_switch+0x88a/frame 0xfffffe0010784e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe0010784e40
_sleep() at _sleep+0x1f0/frame 0xfffffe0010784ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe0010784ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe0010784f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe0010784f30
--- trap 0x565755c4, rip = 0xd28548d689480000, rsp = 0xdf840fc085, rbp = 0xba000024e5058b48 ---
Tracing command kernel pid 0 tid 100014 td 0xfffffe0011eda740
sched_switch() at sched_switch+0x88a/frame 0xfffffe001077fe20
mi_switch() at mi_switch+0xbb/frame 0xfffffe001077fe40
_sleep() at _sleep+0x1f0/frame 0xfffffe001077fec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe001077fef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe001077ff30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe001077ff30
--- trap 0, rip = 0, rsp = 0x200000000000, rbp = 0 ---
Tracing command kernel pid 0 tid 100016 td 0xfffffe0011ed9900
sched_switch() at sched_switch+0x88a/frame 0xfffffe0010775e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe0010775e40
_sleep() at _sleep+0x1f0/frame 0xfffffe0010775ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe0010775ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe0010775f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe0010775f30
--- trap 0x342f3412, rip = 0, rsp = 0, rbp = 0xd198cbb94cdc23aa ---
Tracing command kernel pid 0 tid 100017 td 0xfffffe0011f6e720
sched_switch() at sched_switch+0x88a/frame 0xfffffe00853b3e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00853b3e40
_sleep() at _sleep+0x1f0/frame 0xfffffe00853b3ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00853b3ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00853b3f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00853b3f30
Tracing command kernel pid 0 tid 100018 td 0xfffffe0011f6e000
sched_switch() at sched_switch+0x88a/frame 0xfffffe00853aee20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00853aee40
_sleep() at _sleep+0x1f0/frame 0xfffffe00853aeec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00853aeef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00853aef30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00853aef30
Tracing command kernel pid 0 tid 100021 td 0xfffffe0011f6c900
sched_switch() at sched_switch+0x88a/frame 0xfffffe00107fce20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00107fce40
_sleep() at _sleep+0x1f0/frame 0xfffffe00107fcec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00107fcef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00107fcf30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00107fcf30
--- trap 0xfffc700d, rip = 0xfde08302e2832043, rsp = 0xe81febffffd531e8, rbp = 0x8a0824448b48ffff ---
Tracing command kernel pid 0 tid 100022 td 0xfffffe0011f6c1e0
sched_switch() at sched_switch+0x88a/frame 0xfffffe00107f7e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00107f7e40
_sleep() at _sleep+0x1f0/frame 0xfffffe00107f7ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00107f7ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00107f7f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00107f7f30
--- trap 0xe8f78948, rip = 0x487934b70f422b7e, rsp = 0x8e840ffff8834800, rbp = 0x89483024548b4824 ---
Tracing command kernel pid 0 tid 100023 td 0xfffffe0011f6bac0
sched_switch() at sched_switch+0x88a/frame 0xfffffe00107f2e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00107f2e40
_sleep() at _sleep+0x1f0/frame 0xfffffe00107f2ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00107f2ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00107f2f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00107f2f30
--- trap 0x78aa, rip = 0x485355f489495441, rsp = 0x246c6349df894808, rbp = 0x5ce851ee89485300 ---
Tracing command kernel pid 0 tid 100024 td 0xfffffe0011f6b3a0
sched_switch() at sched_switch+0x88a/frame 0xfffffe00107ede20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00107ede40
_sleep() at _sleep+0x1f0/frame 0xfffffe00107edec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00107edef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00107edf30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00107edf30
--- trap 0x558b4818, rip = 0x474ff85485041c3, rsp = 0x107f8b4850c3c0b6, rbp = 0x1892158d480000c6 ---
Tracing command kernel pid 0 tid 100025 td 0xfffffe0011f72020
sched_switch() at sched_switch+0x88a/frame 0xfffffe00107e8e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00107e8e40
_sleep() at _sleep+0x1f0/frame 0xfffffe00107e8ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00107e8ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00107e8f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00107e8f30
--- trap 0x1644e800, rip = 0x8024948b48, rsp = 0x1e283c2890874ff, rbp = 0x752c244c39000000 ---
Tracing command kernel pid 0 tid 100026 td 0xfffffe0011f71900
sched_switch() at sched_switch+0x88a/frame 0xfffffe00107e3e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00107e3e40
_sleep() at _sleep+0x1f0/frame 0xfffffe00107e3ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00107e3ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00107e3f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00107e3f30
--- trap 0x68b4820, rip = 0x48c300000001b8c3, rsp = 0x9e820d8d48fb8948, rbp = 0x481024448d481024 ---
Tracing command kernel pid 0 tid 100027 td 0xfffffe0011f711e0
sched_switch() at sched_switch+0x88a/frame 0xfffffe00107dee20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00107dee40
_sleep() at _sleep+0x1f0/frame 0xfffffe00107deec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00107deef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00107def30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00107def30
--- trap 0, rip = 0x100000001000, rsp = 0x6000002000000000, rbp = 0 ---
Tracing command kernel pid 0 tid 100028 td 0xfffffe0011f70ac0
sched_switch() at sched_switch+0x88a/frame 0xfffffe00107d9e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00107d9e40
_sleep() at _sleep+0x1f0/frame 0xfffffe00107d9ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00107d9ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00107d9f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00107d9f30
--- trap 0, rip = 0xafafafaf6c617470, rsp = 0xafafafafafafafaf, rbp = 0x30646870 ---
Tracing command kernel pid 0 tid 100035 td 0xfffffe0011f74c80
sched_switch() at sched_switch+0x88a/frame 0xfffffe0085409e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe0085409e40
_sleep() at _sleep+0x1f0/frame 0xfffffe0085409ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe0085409ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe0085409f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe0085409f30
Tracing command kernel pid 0 tid 100039 td 0xfffffe0011f73000
sched_switch() at sched_switch+0x88a/frame 0xfffffe00853f5e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00853f5e40
_sleep() at _sleep+0x1f0/frame 0xfffffe00853f5ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00853f5ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00853f5f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00853f5f30
Tracing command kernel pid 0 tid 100040 td 0xfffffe0011f72740
sched_switch() at sched_switch+0x88a/frame 0xfffffe00853f0e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00853f0e40
_sleep() at _sleep+0x1f0/frame 0xfffffe00853f0ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00853f0ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00853f0f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00853f0f30
Tracing command kernel pid 0 tid 100044 td 0xfffffe0011fb2000
sched_switch() at sched_switch+0x88a/frame 0xfffffe00853dce20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00853dce40
_sleep() at _sleep+0x1f0/frame 0xfffffe00853dcec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00853dcef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00853dcf30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00853dcf30
Tracing command kernel pid 0 tid 100094 td 0xfffffe008eace720
sched_switch() at sched_switch+0x88a/frame 0xfffffe00854bddf0
mi_switch() at mi_switch+0xbb/frame 0xfffffe00854bde10
_sleep() at _sleep+0x1f0/frame 0xfffffe00854bde90
vtballoon_thread() at vtballoon_thread+0xd9/frame 0xfffffe00854bdef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00854bdf30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00854bdf30
Tracing command kernel pid 0 tid 100103 td 0xfffffe008ead2020
sched_switch() at sched_switch+0x88a/frame 0xfffffe0085535e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe0085535e40
_sleep() at _sleep+0x1f0/frame 0xfffffe0085535ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe0085535ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe0085535f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe0085535f30
Tracing command kernel pid 0 tid 100104 td 0xfffffe008ead1900
sched_switch() at sched_switch+0x88a/frame 0xfffffe0085530e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe0085530e40
_sleep() at _sleep+0x1f0/frame 0xfffffe0085530ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe0085530ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe0085530f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe0085530f30
Tracing command kernel pid 0 tid 100105 td 0xfffffe0090d00720
sched_switch() at sched_switch+0x88a/frame 0xfffffe008552be20
mi_switch() at mi_switch+0xbb/frame 0xfffffe008552be40
_sleep() at _sleep+0x1f0/frame 0xfffffe008552bec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe008552bef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe008552bf30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe008552bf30
Tracing command kernel pid 0 tid 100106 td 0xfffffe0090d00000
sched_switch() at sched_switch+0x88a/frame 0xfffffe0085526e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe0085526e40
_sleep() at _sleep+0x1f0/frame 0xfffffe0085526ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe0085526ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe0085526f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe0085526f30
Tracing command kernel pid 0 tid 100107 td 0xfffffe0090d04020
sched_switch() at sched_switch+0x88a/frame 0xfffffe00855a5e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00855a5e40
_sleep() at _sleep+0x1f0/frame 0xfffffe00855a5ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00855a5ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00855a5f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00855a5f30
Tracing command kernel pid 0 tid 100131 td 0xfffffe0091cbd000
sched_switch() at sched_switch+0x88a/frame 0xfffffe00855cde50
mi_switch() at mi_switch+0xbb/frame 0xfffffe00855cde70
msleep_spin_sbt() at msleep_spin_sbt+0x186/frame 0xfffffe00855cdec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xf1/frame 0xfffffe00855cdef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00855cdf30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00855cdf30
Tracing command kernel pid 0 tid 100135 td 0xfffffe0091b831e0
sched_switch() at sched_switch+0x88a/frame 0xfffffe00855b9e50
mi_switch() at mi_switch+0xbb/frame 0xfffffe00855b9e70
msleep_spin_sbt() at msleep_spin_sbt+0x186/frame 0xfffffe00855b9ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xf1/frame 0xfffffe00855b9ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00855b9f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00855b9f30
Tracing command kernel pid 0 tid 100136 td 0xfffffe0091b82ac0
sched_switch() at sched_switch+0x88a/frame 0xfffffe00855b4e50
mi_switch() at mi_switch+0xbb/frame 0xfffffe00855b4e70
msleep_spin_sbt() at msleep_spin_sbt+0x186/frame 0xfffffe00855b4ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xf1/frame 0xfffffe00855b4ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00855b4f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00855b4f30
Tracing command kernel pid 0 tid 100137 td 0xfffffe0091b823a0
sched_switch() at sched_switch+0x88a/frame 0xfffffe00855afe50
mi_switch() at mi_switch+0xbb/frame 0xfffffe00855afe70
msleep_spin_sbt() at msleep_spin_sbt+0x186/frame 0xfffffe00855afec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xf1/frame 0xfffffe00855afef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00855aff30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00855aff30
Tracing command kernel pid 0 tid 100139 td 0xfffffe0091cc0900
sched_switch() at sched_switch+0x88a/frame 0xfffffe0091e59e50
mi_switch() at mi_switch+0xbb/frame 0xfffffe0091e59e70
msleep_spin_sbt() at msleep_spin_sbt+0x186/frame 0xfffffe0091e59ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xf1/frame 0xfffffe0091e59ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe0091e59f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe0091e59f30
Tracing command kernel pid 0 tid 100140 td 0xfffffe0091cc01e0
sched_switch() at sched_switch+0x88a/frame 0xfffffe0091e54e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe0091e54e40
_sleep() at _sleep+0x1f0/frame 0xfffffe0091e54ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe0091e54ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe0091e54f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe0091e54f30
Tracing command kernel pid 0 tid 100142 td 0xfffffe0091cbf3a0
sched_switch() at sched_switch+0x88a/frame 0xfffffe0091e4ae20
mi_switch() at mi_switch+0xbb/frame 0xfffffe0091e4ae40
_sleep() at _sleep+0x1f0/frame 0xfffffe0091e4aec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe0091e4aef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe0091e4af30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe0091e4af30
Tracing command kernel pid 0 tid 100155 td 0xfffffe0094df2e40
sched_switch() at sched_switch+0x88a/frame 0xfffffe00a5b5be20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00a5b5be40
_sleep() at _sleep+0x1f0/frame 0xfffffe00a5b5bec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00a5b5bef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00a5b5bf30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00a5b5bf30
Tracing command kernel pid 0 tid 100156 td 0xfffffe0094df2720
sched_switch() at sched_switch+0x88a/frame 0xfffffe00a5b56e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00a5b56e40
_sleep() at _sleep+0x1f0/frame 0xfffffe00a5b56ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00a5b56ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00a5b56f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00a5b56f30
Tracing command kernel pid 0 tid 100157 td 0xfffffe0094df2000
sched_switch() at sched_switch+0x88a/frame 0xfffffe00a5b51e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00a5b51e40
_sleep() at _sleep+0x1f0/frame 0xfffffe00a5b51ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00a5b51ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00a5b51f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00a5b51f30
Tracing command kernel pid 0 tid 100158 td 0xfffffe0094ce6740
sched_switch() at sched_switch+0x88a/frame 0xfffffe00a5b4ce20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00a5b4ce40
_sleep() at _sleep+0x1f0/frame 0xfffffe00a5b4cec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00a5b4cef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00a5b4cf30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00a5b4cf30
Tracing command kernel pid 0 tid 100159 td 0xfffffe0094ce6020
sched_switch() at sched_switch+0x88a/frame 0xfffffe00a5b47e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00a5b47e40
_sleep() at _sleep+0x1f0/frame 0xfffffe00a5b47ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00a5b47ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00a5b47f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00a5b47f30
Tracing command kernel pid 0 tid 100160 td 0xfffffe0094ce5900
sched_switch() at sched_switch+0x88a/frame 0xfffffe00a5b42e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00a5b42e40
_sleep() at _sleep+0x1f0/frame 0xfffffe00a5b42ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00a5b42ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00a5b42f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00a5b42f30
Tracing command kernel pid 0 tid 100161 td 0xfffffe0094ce51e0
sched_switch() at sched_switch+0x88a/frame 0xfffffe00a5b3de20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00a5b3de40
_sleep() at _sleep+0x1f0/frame 0xfffffe00a5b3dec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00a5b3def0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00a5b3df30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00a5b3df30
Tracing command kernel pid 0 tid 100162 td 0xfffffe0094ce4ac0
sched_switch() at sched_switch+0x88a/frame 0xfffffe00a5b38e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00a5b38e40
_sleep() at _sleep+0x1f0/frame 0xfffffe00a5b38ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00a5b38ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00a5b38f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00a5b38f30
Tracing command kernel pid 0 tid 100163 td 0xfffffe0094df6740
sched_switch() at sched_switch+0x88a/frame 0xfffffe00a5b33e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00a5b33e40
_sleep() at _sleep+0x1f0/frame 0xfffffe00a5b33ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00a5b33ef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00a5b33f30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00a5b33f30
Tracing command kernel pid 0 tid 100164 td 0xfffffe0094df6020
sched_switch() at sched_switch+0x88a/frame 0xfffffe00a5b2ee20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00a5b2ee40
_sleep() at _sleep+0x1f0/frame 0xfffffe00a5b2eec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frame 0xfffffe00a5b2eef0
fork_exit() at fork_exit+0x7f/frame 0xfffffe00a5b2ef30
fork_trampoline() at fork_trampoline+0xe/frame 0xfffffe00a5b2ef30
Tracing command kernel pid 0 tid 100165 td 0xfffffe0094df5900
sched_switch() at sched_switch+0x88a/frame 0xfffffe00a5b29e20
mi_switch() at mi_switch+0xbb/frame 0xfffffe00a5b29e40
_sleep() at _sleep+0x1f0/frame 0xfffffe00a5b29ec0
taskqueue_thread_loop() at taskqueue_thread_loop+0xb1/frameconfig.txt������������������������������������������������������������������������������������������0600����0�������0�������14036�������14602173604�  7542� �����������������������������������������������������������������������������������������������������ustar���root����������������������������wheel������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������options	CONFIG_AUTOGENERATED
ident	pfSense
machine	amd64
cpu	HAMMER
makeoptions	WITH_CTF=1
makeoptions	DEBUG=-g
options	RSS
options	RATELIMIT
options	MROUTING
options	MSGTQL=2048
options	MSGSSZ=32
options	MSGSEG=512
options	MSGMNI=40
options	MSGMNB=8192
options	ALTQ_CODEL
options	ALTQ_NOPCC
options	ALTQ_FAIRQ
options	ALTQ_PRIQ
options	ALTQ_HFSC
options	ALTQ_RIO
options	ALTQ_RED
options	ALTQ_CBQ
options	ALTQ
options	IPSEC
options	TCP_SIGNATURE
options	NETGRAPH_PRED1
options	NETGRAPH_DEFLATE
options	NETGRAPH_CAR
options	NETGRAPH_PIPE
options	NETGRAPH_TCPMSS
options	NETGRAPH_TEE
options	NETGRAPH_HOLE
options	NETGRAPH_FRAME_RELAY
options	NETGRAPH_ASYNC
options	NETGRAPH_ECHO
options	NETGRAPH_CISCO
options	NETGRAPH_BRIDGE
options	NETGRAPH_ONE2MANY
options	NETGRAPH_LMI
options	NETGRAPH_KSOCKET
options	NETGRAPH_VJC
options	NETGRAPH_UI
options	NETGRAPH_MPPC_ENCRYPTION
options	NETGRAPH_TTY
options	NETGRAPH_SOCKET
options	NETGRAPH_RFC1490
options	NETGRAPH_PPTPGRE
options	NETGRAPH_PPPOE
options	NETGRAPH_EIFACE
options	NETGRAPH_IFACE
options	NETGRAPH_ETHER
options	NETGRAPH_BPF
options	NETGRAPH_L2TP
options	NETGRAPH_VLAN
options	NETGRAPH
options	IPSTEALTH
options	IPFIREWALL_VERBOSE
options	IPFIREWALL_DEFAULT_TO_ACCEPT
options	ALQ
options	NULLFS
options	GEOM_BDE
options	GEOM_ELI
options	GEOM_UZIP
options	GEOM_MIRROR
options	IICHID_SAMPLING
options	EVDEV_SUPPORT
options	XENHVM
options	ATH_ENABLE_11N
options	AH_AR5416_INTERRUPT_MITIGATION
options	IEEE80211_SUPPORT_MESH
options	SC_PIXEL_MODE
options	PPS_SYNC
options	COMPAT_LINUXKPI
options	PCI_IOV
options	PCI_HP
options	IOMMU
options	SMP
options	NETGDB
options	NETDUMP
options	DEBUGNET
options	ZSTDIO
options	GZIO
options	EKCD
options	VERBOSE_SYSINIT=0
options	GDB
options	DDB
options	KDB
options	RCTL
options	RACCT_DEFAULT_TO_DISABLED
options	RACCT
options	INCLUDE_CONFIG_FILE
options	DDB_CTF
options	KDTRACE_HOOKS
options	KDTRACE_FRAME
options	CAPABILITIES
options	CAPABILITY_MODE
options	AUDIT
options	HWPMC_HOOKS
options	KBD_INSTALL_CDEV
options	PRINTF_BUFR_SIZE=128
options	_KPOSIX_PRIORITY_SCHEDULING
options	SYSVSEM
options	SYSVMSG
options	SYSVSHM
options	STACK
options	KTRACE
options	SCSI_DELAY=5000
options	COMPAT_FREEBSD13
options	COMPAT_FREEBSD12
options	COMPAT_FREEBSD11
options	COMPAT_FREEBSD10
options	COMPAT_FREEBSD9
options	COMPAT_FREEBSD32
options	EFIRT
options	GEOM_LABEL
options	GEOM_RAID
options	TMPFS
options	PSEUDOFS
options	PROCFS
options	CD9660
options	MSDOSFS
options	NFS_ROOT
options	NFSLOCKD
options	NFSD
options	NFSCL
options	MD_ROOT
options	QUOTA
options	UFS_GJOURNAL
options	UFS_DIRHASH
options	UFS_ACL
options	SOFTUPDATES
options	FFS
options	KERN_TLS
options	SCTP_SUPPORT
options	TCP_RFC7413
options	TCP_HHOOK
options	TCP_BLACKBOX
options	TCP_OFFLOAD
options	FIB_ALGO
options	ROUTE_MPATH
options	IPSEC_SUPPORT
options	INET6
options	INET
options	VIMAGE
options	PREEMPTION
options	NUMA
options	SCHED_ULE
options	NETLINK
options	NEW_PCIB
options	CC_CUBIC
options	GEOM_PART_GPT
options	GEOM_PART_MBR
options	GEOM_PART_EBR
options	GEOM_PART_BSD
options	EARLY_AP_STARTUP
options	DDB
options	TMPFS
options	PPS_SYNC
device	isa
device	mem
device	io
device	uart_ns8250
device	cpufreq
device	acpi
device	smbios
device	pci
device	fdc
device	ahci
device	ata
device	mvs
device	siis
device	ahc
device	ahd
device	hptiop
device	isp
device	mpt
device	mps
device	mpr
device	sym
device	isci
device	ocs_fc
device	pvscsi
device	scbus
device	ch
device	da
device	sa
device	cd
device	pass
device	ses
device	arcmsr
device	ciss
device	ips
device	smartpqi
device	tws
device	aac
device	aacp
device	aacraid
device	ida
device	mfi
device	mlx
device	mrsas
device	nvme
device	nvd
device	vmd
device	atkbdc
device	atkbd
device	psm
device	kbdmux
device	vga
device	splash
device	sc
device	vt
device	vt_vga
device	vt_efifb
device	vt_vbefb
device	agp
device	cbb
device	cardbus
device	uart
device	ppc
device	ppbus
device	lpt
device	ppi
device	puc
device	iflib
device	em
device	igc
device	ix
device	ixv
device	ixl
device	iavf
device	ice
device	vmx
device	axp
device	bxe
device	le
device	ti
device	mlx5
device	mlxfw
device	mlx5en
device	miibus
device	ae
device	age
device	alc
device	ale
device	bce
device	bfe
device	bge
device	cas
device	dc
device	et
device	fxp
device	gem
device	jme
device	lge
device	msk
device	nfe
device	nge
device	re
device	rl
device	sge
device	sis
device	sk
device	ste
device	stge
device	vge
device	vr
device	xl
device	wlan
device	wlan_wep
device	wlan_ccmp
device	wlan_tkip
device	wlan_amrr
device	ath
device	ath_hal
device	ath_rate_sample
device	ipw
device	iwi
device	iwn
device	malo
device	mwl
device	ral
device	wpi
device	crypto
device	loop
device	padlock_rng
device	rdrand_rng
device	ether
device	vlan
device	tuntap
device	md
device	gif
device	firmware
device	xz
device	bpf
device	uhci
device	ohci
device	ehci
device	xhci
device	usb
device	ukbd
device	umass
device	sound
device	snd_cmi
device	snd_csa
device	snd_emu10kx
device	snd_es137x
device	snd_hda
device	snd_ich
device	snd_via8233
device	mmc
device	mmcsd
device	sdhci
device	virtio
device	virtio_pci
device	vtnet
device	virtio_blk
device	virtio_scsi
device	virtio_balloon
device	kvm_clock
device	hyperv
device	xenefi
device	xenpci
device	xentimer
device	netmap
device	evdev
device	uinput
device	hid
device	wlan_rssadapt
device	wlan_xauth
device	wlan_acl
device	iwm
device	iwmfw
device	iwifw
device	ipwfw
device	wpifw
device	iwnfw
device	uath
device	ralfw
device	ural
device	urtw
device	rum
device	mwlfw
device	zyd
device	upgt
device	udav
device	axe
device	axge
device	aue
device	cue
device	kue
device	mos
device	rsu
device	rsufw
device	rtwn
device	rtwnfw
device	rtwn_pci
device	rtwn_usb
device	run
device	runfw
device	rue
device	bwn
device	bwi
device	ufoma
device	ucom
device	uslcom
device	uplcom
device	umct
device	uvisor
device	uark
device	uftdi
device	uvscom
device	umodem
device	u3g
device	cdce
device	uhid
device	firewire
device	sbp
device	gre
device	if_bridge
device	carp
device	lagg
device	vte
device	enc
device	pf
device	pflog
device	pfsync
device	rndtest
device	speaker
device	mxge
device	cxgb
device	cxgbe
device	oce
device	mlx4
device	mlx4en
device	qlxgb
device	bnxt
device	virtio_console
��������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������msgbuf.txt������������������������������������������������������������������������������������������0600����0�������0�������41101�������14602173604�  7551� �����������������������������������������������������������������������������������������������������ustar���root����������������������������wheel������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������---<<BOOT>>---
Copyright (c) 1992-2023 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
	The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
    root@freebsd:/var/jenkins/workspace/pfSense-CE-snapshots-2_7_2-main/obj/amd64/StdASW5b/var/jenkins/workspace/pfSense-CE-snapshots-2_7_2-main/sources/FreeBSD-src-RELENG_2_7_2/amd64.amd64/sys/pfSense amd64
FreeBSD clang version 16.0.6 (https://github.com/llvm/llvm-project.git llvmorg-16.0.6-0-g7cbf1a259152)
VT(efifb): resolution 1280x800
CPU: QEMU Virtual CPU version 2.5+ (1996.85-MHz K8-class CPU)
  Origin="GenuineIntel"  Id=0x60fb1  Family=0xf  Model=0x6b  Stepping=1
  Features=0x1783fbfd<FPU,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,MMX,FXSR,SSE,SSE2,HTT>
  Features2=0x82b82201<SSE3,SSSE3,CX16,SSE4.1,SSE4.2,x2APIC,POPCNT,AESNI,HV>
  AMD Features=0x20100800<SYSCALL,NX,LM>
  AMD Features2=0x1<LAHF>
Hypervisor: Origin = "KVMKVMKVM"
real memory  = 8589934592 (8192 MB)
avail memory = 8182571008 (7803 MB)
Event timer "LAPIC" quality 100
ACPI APIC Table: <BOCHS  BXPC    >
FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s)
random: unblocking device.
ioapic0 <Version 1.1> irqs 0-23
Launching APs: 1
TCP_ratelimit: Is now initialized
wlan: mac acl policy registered
ipw_bss: You need to read the LICENSE file in /usr/share/doc/legal/intel_ipw.LICENSE.
ipw_bss: If you agree with the license, set legal.intel_ipw.license_ack=1 in /boot/loader.conf.
module_register_init: MOD_LOAD (ipw_bss_fw, 0xffffffff807475a0, 0) error 1
ipw_ibss: You need to read the LICENSE file in /usr/share/doc/legal/intel_ipw.LICENSE.
ipw_ibss: If you agree with the license, set legal.intel_ipw.license_ack=1 in /boot/loader.conf.
module_register_init: MOD_LOAD (ipw_ibss_fw, 0xffffffff80747650, 0) error 1
ipw_monitor: You need to read the LICENSE file in /usr/share/doc/legal/intel_ipw.LICENSE.
ipw_monitor: If you agree with the license, set legal.intel_ipw.license_ack=1 in /boot/loader.conf.
module_register_init: MOD_LOAD (ipw_monitor_fw, 0xffffffff80747700, 0) error 1
iwi_bss: You need to read the LICENSE file in /usr/share/doc/legal/intel_iwi.LICENSE.
iwi_bss: If you agree with the license, set legal.intel_iwi.license_ack=1 in /boot/loader.conf.
module_register_init: MOD_LOAD (iwi_bss_fw, 0xffffffff80765180, 0) error 1
iwi_ibss: You need to read the LICENSE file in /usr/share/doc/legal/intel_iwi.LICENSE.
iwi_ibss: If you agree with the license, set legal.intel_iwi.license_ack=1 in /boot/loader.conf.
module_register_init: MOD_LOAD (iwi_ibss_fw, 0xffffffff80765230, 0) error 1
iwi_monitor: You need to read the LICENSE file in /usr/share/doc/legal/intel_iwi.LICENSE.
iwi_monitor: If you agree with the license, set legal.intel_iwi.license_ack=1 in /boot/loader.conf.
module_register_init: MOD_LOAD (iwi_monitor_fw, 0xffffffff807652e0, 0) error 1
random: entropy device external interface
kbd1 at kbdmux0
WARNING: Device "spkr" is Giant locked and may be deleted before FreeBSD 14.0.
netgate0: <QEMU Guest>
efirtc0: <EFI Realtime Clock>
efirtc0: registered as a time-of-day clock, resolution 1.000000s
kvmclock0: <KVM paravirtual clock>
Timecounter "kvmclock" frequency 1000000000 Hz quality 975
kvmclock0: registered as a time-of-day clock, resolution 0.000001s
smbios0: <System Management BIOS> at iomem 0x7e9d4000-0x7e9d401e
smbios0: Version: 3.0, BCD Revision: 3.0
acpi0: <BOCHS BXPC>
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
atrtc0: registered as a time-of-day clock, resolution 1.000000s
Event timer "RTC" frequency 32768 Hz quality 0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 100000000 Hz quality 950
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x608-0x60b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
vgapci0: <VGA-compatible display> mem 0x80000000-0x80ffffff,0x8241b000-0x8241bfff at device 1.0 on pci0
vgapci0: Boot video device
uhci0: <Intel 82801I (ICH9) USB controller> port 0x8100-0x811f irq 16 at device 26.0 on pci0
usbus0 on uhci0
usbus0: 12Mbps Full Speed USB v1.0
uhci1: <Intel 82801I (ICH9) USB controller> port 0x80e0-0x80ff irq 17 at device 26.1 on pci0
usbus1 on uhci1
usbus1: 12Mbps Full Speed USB v1.0
uhci2: <Intel 82801I (ICH9) USB controller> port 0x80c0-0x80df irq 18 at device 26.2 on pci0
usbus2 on uhci2
usbus2: 12Mbps Full Speed USB v1.0
ehci0: <Intel 82801I (ICH9) USB 2.0 controller> mem 0x8241a000-0x8241afff irq 19 at device 26.7 on pci0
usbus3: EHCI version 1.0
usbus3 on ehci0
usbus3: 480Mbps High Speed USB v2.0
hdac0: <Intel 82801I HDA Controller> mem 0x82410000-0x82413fff irq 16 at device 27.0 on pci0
pcib1: <ACPI PCI-PCI bridge> mem 0x82419000-0x82419fff irq 16 at device 28.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> mem 0x82418000-0x82418fff irq 16 at device 28.1 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> mem 0x82417000-0x82417fff irq 16 at device 28.2 on pci0
pci3: <ACPI PCI bus> on pcib3
pcib4: <ACPI PCI-PCI bridge> mem 0x82416000-0x82416fff irq 16 at device 28.3 on pci0
pci4: <ACPI PCI bus> on pcib4
uhci3: <Intel 82801I (ICH9) USB controller> port 0x80a0-0x80bf irq 16 at device 29.0 on pci0
usbus4 on uhci3
usbus4: 12Mbps Full Speed USB v1.0
uhci4: <Intel 82801I (ICH9) USB controller> port 0x8080-0x809f irq 17 at device 29.1 on pci0
usbus5 on uhci4
usbus5: 12Mbps Full Speed USB v1.0
uhci5: <Intel 82801I (ICH9) USB controller> port 0x8060-0x807f irq 18 at device 29.2 on pci0
usbus6 on uhci5
usbus6: 12Mbps Full Speed USB v1.0
ehci1: <Intel 82801I (ICH9) USB 2.0 controller> mem 0x82415000-0x82415fff irq 19 at device 29.7 on pci0
usbus7: EHCI version 1.0
usbus7 on ehci1
usbus7: 480Mbps High Speed USB v2.0
pcib5: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci5: <ACPI PCI bus> on pcib5
pcib6: <ACPI PCI-PCI bridge> mem 0x81a00000-0x81a000ff irq 21 at device 1.0 on pci5
pci6: <ACPI PCI bus> on pcib6
virtio_pci0: <VirtIO PCI (legacy) Balloon adapter> port 0x7000-0x703f mem 0x800100000-0x800103fff irq 20 at device 3.0 on pci6
vtballoon0: <VirtIO Balloon Adapter> on virtio_pci0
igc0: <Intel(R) Ethernet Controller I226-V> mem 0x81800000-0x818fffff,0x81908000-0x8190bfff irq 21 at device 16.0 on pci6
igc0: Using 1024 TX descriptors and 1024 RX descriptors
igc0: Using 2 RX queues 2 TX queues
igc0: Using MSI-X interrupts with 3 vectors
<6>igc0: Ethernet address: 60:be:b4:0c:6b:e1
<6>igc0: netmap queues/slots: TX 2/1024, RX 2/1024
igc1: <Intel(R) Ethernet Controller I226-V> mem 0x81700000-0x817fffff,0x81904000-0x81907fff irq 22 at device 17.0 on pci6
igc1: Using 1024 TX descriptors and 1024 RX descriptors
igc1: Using 2 RX queues 2 TX queues
igc1: Using MSI-X interrupts with 3 vectors
<6>igc1: Ethernet address: 60:be:b4:0c:6b:e3
<6>igc1: netmap queues/slots: TX 2/1024, RX 2/1024
igc2: <Intel(R) Ethernet Controller I226-V> mem 0x81600000-0x816fffff,0x81900000-0x81903fff irq 20 at device 27.0 on pci6
igc2: Using 1024 TX descriptors and 1024 RX descriptors
igc2: Using 2 RX queues 2 TX queues
igc2: Using MSI-X interrupts with 3 vectors
<6>igc2: Ethernet address: 60:be:b4:0c:6b:e4
<6>igc2: netmap queues/slots: TX 2/1024, RX 2/1024
pcib7: <ACPI PCI-PCI bridge> mem 0x81a01000-0x81a010ff irq 22 at device 2.0 on pci5
pci7: <ACPI PCI bus> on pcib7
pcib8: <ACPI PCI-PCI bridge> mem 0x81a02000-0x81a020ff irq 23 at device 3.0 on pci5
pci8: <ACPI PCI bus> on pcib8
pcib9: <ACPI PCI-PCI bridge> mem 0x81a03000-0x81a030ff irq 20 at device 4.0 on pci5
pci9: <ACPI PCI bus> on pcib9
virtio_pci1: <VirtIO PCI (legacy) SCSI adapter> port 0x6000-0x603f mem 0x81000000-0x81000fff,0x800000000-0x800003fff irq 21 at device 1.0 on pci9
vtscsi0: <VirtIO SCSI Adapter> on virtio_pci1
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci0: <Intel ICH9 AHCI SATA controller> port 0x8040-0x805f mem 0x82414000-0x82414fff irq 16 at device 31.2 on pci0
ahci0: AHCI v1.00 with 6 1.5Gbps ports, Port Multiplier not supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich5: <AHCI channel> at channel 5 on ahci0
acpi_syscontainer0: <System Container> on acpi0
vmgenc0: <VM Generation Counter> on acpi0
acpi_syscontainer1: <System Container> port 0xb2-0xb3 on acpi0
acpi_syscontainer2: <System Container> port 0xcd8-0xce3 on acpi0
acpi_syscontainer3: <System Container> port 0x620-0x62f on acpi0
acpi_syscontainer4: <System Container> port 0xcc0-0xcd7 on acpi0
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
psm0: <PS/2 Mouse> irq 12 on atkbdc0
psm0: [GIANT-LOCKED]
WARNING: Device "psm" is Giant locked and may be deleted before FreeBSD 14.0.
psm0: model IntelliMouse Explorer, device ID 4
attimer0: <AT timer> at port 0x40 on isa0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
Timecounters tick every 10.000 msec
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
ugen7.1: <Intel EHCI root HUB> at usbus7
ugen6.1: <Intel UHCI root HUB> at usbus6
uhub0 on usbus7
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus7
uhub1 on usbus6
uhub1: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus6
ugen4.1: <Intel UHCI root HUB> at usbus4
ugen5.1: <Intel UHCI root HUB> at usbus5
uhub2 on usbus4
uhub2: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4
ugen2.1: <Intel UHCI root HUB> at usbus2
uhub3 on usbus5
uhub3: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus5
ugen3.1: <Intel EHCI root HUB> at usbus3
uhub4 on usbus2
uhub5 on usbus3
uhub5: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
uhub4: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
ugen0.1: <Intel UHCI root HUB> at usbus0
ugen1.1: <Intel UHCI root HUB> at usbus1
uhub6 on usbus0
uhub6: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
uhub7 on usbus1
uhub7: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
Trying to mount root from zfs:pfSense/ROOT/default []...
uhub1: 2 ports with 2 removable, self powered
uhub2: 2 ports with 2 removable, self powered
uhub3: 2 ports with 2 removable, self powered
uhub4: 2 ports with 2 removable, self powered
uhub6: 2 ports with 2 removable, self powered
uhub7: 2 ports with 2 removable, self powered
Root mount waiting for: usbus3 usbus7 CAM
uhub0: 6 ports with 6 removable, self powered
uhub5: 6 ports with 6 removable, self powered
ugen7.2: <QEMU QEMU USB Tablet> at usbus7
uhid0 on uhub0
uhid0: <QEMU QEMU USB Tablet, class 0/0, rev 2.00/0.00, addr 2> on usbus7
Root mount waiting for: CAM
cd0 at ahcich1 bus 0 scbus2 target 0 lun 0
cd0: <QEMU QEMU DVD-ROM 2.5+> Removable CD-ROM SCSI device
cd0: Serial Number QM00003
cd0: 150.000MB/s transfers (SATA 1.x, UDMA5, ATAPI 12bytes, PIO 8192bytes)
cd0: 834MB (427086 2048 byte sectors)
da0 at vtscsi0 bus 0 scbus0 target 0 lun 0
da0: <QEMU QEMU HARDDISK 2.5+> Fixed Direct Access SPC-3 SCSI device
da0: 300.000MB/s transfers
da0: Command Queueing enabled
da0: 10240MB (20971520 512 byte sectors)
<118>Configuring crash dumps...
<118>Using /dev/da0p3 for dump device.
<118>/dev/gpt/efiboot0: 6 files, 259 MiB free (16549 clusters)
<118>FIXED
<118>/dev/gpt/efiboot0: MARKING FILE SYSTEM CLEAN
<118>Filesystems are clean, continuing...
<118>Mounting filesystems...
<118>Mounting ZFS boot environment... done.
<118>
<118>        __
<118> _ __  / _|___  ___ _ __  ___  ___
<118>| '_ \| |_/ __|/ _ \ '_ \/ __|/ _ \
<118>| |_) |  _\__ \  __/ | | \__ \  __/
<118>| .__/|_| |___/\___|_| |_|___/\___|
<118>|_|
<118>
<118>
<118>Welcome to pfSense 2.7.2-RELEASE...
<118>
<118>Checking dump device /dev/da0p3 for crash dumps ... no crash dumps on /dev/da0p3.
<118>...ELF ldconfig path: /lib /usr/lib /usr/lib/compat /usr/local/lib /usr/local/lib/compat/pkg /usr/local/lib/compat/pkg /usr/local/lib/ipsec /usr/local/lib/perl5/5.34/mach/CORE
<118>32-bit compatibility ldconfig path:
<118>done.
<118>>>> Removing vital flag from php82... done.
<118>7580
<118>External config loader 1.0 is now starting... da0p1 da0p2 da0p4
<118>Launching the init system...Updating CPU Microcode...
CPU: QEMU Virtual CPU version 2.5+ (1996.80-MHz K8-class CPU)
  Features=0x178bfbfd<FPU,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
<118>Done.
<118> done.
<118>Initializing................... done.
<118>Starting device manager (devd)...
ichsmb0: <Intel 82801I (ICH9) SMBus controller> port 0x8000-0x803f irq 16 at device 31.3 on pci0
smbus0: <System Management Bus> on ichsmb0
<118>done.
<118>Loading configuration....done.
<118>Configuring WireGuard tunnels...
<6>wg0: changing name to 'tun_wg0'
<6>tun_wg0: link state changed to UP
<6>igc0: link state changed to UP
<6>igc1: link state changed to UP
<118>done.
<118>Updating configuration...done.
<118>Checking config backups consistency...done.
<118>Setting up extended sysctls...done.
<118>Setting timezone...done.
<118>Configuring loopback interface...
<6>lo0: link state changed to UP
<118>done.
<118>Starting syslog...done.
<118>Setting up interfaces microcode...done.
<118>Configuring loopback interface...done.
<118>Configuring WAN interface...
<6>igc0: link state changed to DOWN
<118>done.
<118>Configuring HOME_VPN interface...done.
<118>Configuring LAN interface...
<6>igc1: link state changed to DOWN
<118>done.
<118>Configuring CARP settings...done.
<118>Syncing OpenVPN settings...done.
<118>Configuring firewall.
<6>pflog0: promiscuous mode enabled
<118>.
load_dn_sched dn_sched FIFO loaded
load_dn_sched dn_sched QFQ loaded
load_dn_sched dn_sched RR loaded
load_dn_sched dn_sched WF2Q+ loaded
load_dn_sched dn_sched PRIO loaded
load_dn_sched dn_sched FQ_CODEL loaded
load_dn_sched dn_sched FQ_PIE loaded
load_dn_aqm dn_aqm CODEL loaded
load_dn_aqm dn_aqm PIE loaded
<118>....done.
<118>Starting PFLOG...done.
<118>Setting up gateway monitors...done.
<118>Setting up static routes...
[fib_algo] inet.0 (bsearch4#27) rebuild_fd_flm: switching algo to radix4_lockless
<118>done.
<118>Setting up DNSs...
<118>Starting DNS Resolver...
<118>done.
<118>Synchronizing user settings...done.
<118>Configuring CRON...done.
<118>Bootstrapping clock...done.
<118>Starting NTP Server...done.
<118>Starting webConfigurator...done.
<118>Starting DHCP service...done.
<118>Starting DHCPv6 service...done.
<118>Configuring firewall......done.
<118>Generating RRD graphs...done.
<118>Starting CRON... done.
<6>tun_wg0: link state changed to DOWN
<118> Starting package WireGuard...done.
<118> Starting package pfBlockerNG-devel...done.
<118> Starting /usr/local/etc/rc.d/pfb_dnsbl.sh...done.
<118> Starting /usr/local/etc/rc.d/pfb_filter.sh...done.
<118>pfSense 2.7.2-RELEASE amd64 20231206-2010
<118>Bootup complete
Fatal double fault
rip 0xffffffff81255c16 rsp 0xfffffe00107b1d70 rbp 0xfffffe00107b1d70
rax 0x1c158de77117e rdx 0x1c15800000000 rbx 0x1c158de77117e
rcx 0 rsi 0 rdi 0
r8 0 r9 0x2 r10 0
r11 0x1 r12 0xfffff80002a5f828 r13 0
r14 0xffffffff84011000 r15 0xfffff80002a5f800 rflags 0x10246
cs 0x20 ss 0x28 ds 0x3b es 0x3b fs 0x13 gs 0x1b
fsbase 0x4938f9a07120 gsbase 0xffffffff84011000 kgsbase 0
cpuid = 1; apic id = 01
Fatal double fault
rip 0xffffffff8126af94 rsp 0xffffffff83103850 rbp 0xfffffe00a8d38e40
rax 0 rdx 0 rbx 0xfffff80007c97c00
rcx 0xfffffe00a8d38e78 rsi 0xfffff80007c97c00 rdi 0xffffffff83020ab0
r8 0xfffffe00a7701360 r9 0xfffffe00a8d39000 r10 0x1f4
r11 0x81789bd4 r12 0xfffff801f55dd558 r13 0xfffffe00a7700e40
r14 0xfffff80007c97e30 r15 0 rflags 0x10086
fsbase 0x4938f9a07120 gsbase 0xffffffff84010000 kgsbase 0
cpuid = 0; apic id = 00
timeout stopping cpus
panic: double fault
panic: double fault
cpuid = 0
time = 1711863684
KDB: enter: panic
���������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������panic.txt�������������������������������������������������������������������������������������������0600����0�������0�������14����������14602173604�  7136� �����������������������������������������������������������������������������������������������������ustar���root����������������������������wheel������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������double fault��������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������version.txt�����������������������������������������������������������������������������������������0600����0�������0�������457���������14602173604�  7624� �����������������������������������������������������������������������������������������������������ustar���root����������������������������wheel������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������������FreeBSD 14.0-CURRENT amd64 1400094 #1 RELENG_2_7_2-n255948-8d2b56da39c: Wed Dec  6 20:45:47 UTC 2023
I think i’ve eliminated hardware as the cause of the issue, as proxmox on the same box shows an uptime of 26 days where as pfsense (the only VM on proxmox) crashes after 2-3 days.
Any help on this would be greatly appreciated.
Do you have ballooning memory enabled in the VMs? If you’re using hardware passthrough then enabling ballooning memory will cause instability.
Hi, thank you for your reply.
Under the memory tab of Proxmox Pfsesnse VM I have Ballooning Device tick marked in both proxmox boxes. Pfsense crashes on one box and doesn’t on the other.
Just ran a memtest+ on the crashing pfsense and it passed successfully.
Also pfsense on both my boxes rarely uses more than 8% of 8192 MB
If you’re using hardware passthrough you can’t use ballooning memory, the VM needs a block of memory dedicated to it otherwise DMA can read or write to the wrong memory address.
Thank you so much for that valuable bit of information. I went ahead and disabled ballooning on both proxmox boxes.
As for the crashing pfsense I first ran a memtest to ensure the hardware is running fine. I wanted to run mprime on the box, but time was a constraint. I also did a fresh install of pfsense with all my WireGuard tunnel configs , pfblocker. Hopefully it won’t crash again.
Cheers
