Is the redriver and fancy cable still the only option?
I would like to be able to hook a p5800x up directly to my cpu m.2 and not have to use a pci-e card.
I didnāt see anything in the bios about PCI AER but even with the slightly longer connector and basic adapter it linked up at PCIe 4.
I did a bunch of CrystalDiskMark tests on the drive and it got toasty, so Iām going to have to figure out a different mounting solution in order to provide some airflow.
That pricing is I believe the word is OUCHā¦ very ouch.
It looks like the post up the top covers it for $116 USD, not cheap to be honest, considering how expensive that drive is.
With a pcie 4.0 u.2 device?
Same, let me know if you find one that works.
Maybe Delock Produkte 62984 Delock M.2 Key M zu U.2 SFF-8639 NVMe Adapter mit 50 cm Kabel ?
Yes Kioxia CD6 8TB drives.
Iāve been using these for a while now and I havenāt noticed any problems. Everything seems to have linked up at PCIe4.
This one looks interesting, but I noticed that itās got the 2260 form factor & is too small for my consumer boards.
That doesnāt make any sense. If you can handle a 2280 you can handle a 2260. What board?
Also from searching around, looks like @LiKenun got a p5800x working reliably w m2 adapter with redriver
Not necessarily. The holes in the board to support a shorter form factor drive should be present and not every manufacturer had accounted for the fact drives get smaller and smaller over time. What used to barely fit in a 2280 just 2 years ago, now easily fits on a 2240 drive.
+1
Out of curiosity, though, I just checked all the mobos Iāve built in the past couple years. 2230/2242/2260/2280 is the majority of M.2 sockets. Thereās some 2230/2242/2260/2280/22110 placements and some 2242/2260/2280. The most restricted board has one 2242/2260/2280 and three 2260/2280s.
Is there a way to determine which PCIe device might be causing AER reports?
I found and flipped on the AER option on one of my boards (x570 aorus xtreme) and it started spitting out errors:
A corrected hardware error has occurred.
Component: PCI Express Root Port
Error Source: Advanced Error Reporting (PCI Express)
Primary Bus:Device:Function: 0x0:0x1:0x1
Secondary Bus:Device:Function: 0x0:0x0:0x0
Primary Device Name:PCI\VEN_1022&DEV_1483&SUBSYS_14531022&REV_00
Secondary Device Name:
Interestingly, it doesnāt seem to be the optane thatās the cause.
Full error log:
EventData
ErrorSource 4
FRUId {00000000-0000-0000-0000-000000000000}
FRUText
ValidBits 0xdf
PortType 4
Version 0x101
Command 0x406
Status 0x10
Bus 0x0
Device 0x1
Function 0x1
Segment 0x0
SecondaryBus 0x0
SecondaryDevice 0x0
SecondaryFunction 0x0
VendorID 0x1022
DeviceID 0x1483
ClassCode 0x30400
DeviceSerialNumber 0x0
BridgeControl 0x0
BridgeStatus 0x0
UncorrectableErrorStatus 0x0
CorrectableErrorStatus 0x1000
HeaderLog 00000000000000000000000000000000
PrimaryDeviceName PCI\VEN_1022&DEV_1483&SUBSYS_14531022&REV_00
SecondaryDeviceName
Edit 3:
Looked at an X570 system with HWiNFO which is easier to search through, VEN_1022&DEV_1483 (āAMD Family 17h/19h - PCIe GPP Bridge[7:0]ā) are basically all devices that are directly connected to CPU PCIe, on AM4 with the platformās 16 + 4 + 4 PCIe Lane configuration these are:
The X570 chipset chip with 4 Lanes (that would mean a defective motherboard)
The main M.2 SSD slot with 4 Lanes
The big x16 and x8 CPU PCIe slots
I may have a post quite related to this one, having just seen it.
Iām in a world of pain, some significant dollars on 2 Optane drives, both of which arenāt working in 3 different configurations. Should the Original Intel Gen 3 Retail 905P Box cable work with a P5800X? (It works with neither 905P nor the P5800X so Iām having trouble identifying my exact issue)
Definitely not, they only handle PCIe Gen3 without errors. Tested this myself with the ones that came with Optane 905P 480 GB SSDs.
There currently are NO passive adapter chains with cables that can properly connect a PCIe Gen4 U.2/U.3 SSD to a motherboardās M.2 slot, no matter what any item description claims. Unfortunately the PCIe world is full of incompetent people and scammers.
Iāve successfully tested these passive PCIe PCB adapters with Gen4 SSDs, no PCIe Bus Errors after 24 h of sustained load: Delock Products 90091 Delock PCI Express 4.0 x8 Card to 2 x internal U.2 NVMe SFF-8639 - Bifurcation
Let me clarifyā¦
Should the disk even appear? I donāt care if it runs slowly, it doesnāt appear.
If you check my thread, Iāve used the Optane 905P retail cable that (appearsā¦ brand new) with a 905P and a P5800X in
A HP 400 ProDesk Mini, A Lenovo M75Q Gen 2 Tiny and an Orico USB-C to NVMe adapter, all using a powered SATA cable from a HDD USB kit and on all 3 attempts, with both drives, I get no drives recognised.
So either the Optane drives and or optane cable are faulty OR the optane drives and or optane cable donāt like a āMolex to SATA styleā power delivery from my old, crappy, USB C HDD kit
(again see my thread to make sense of it)
As it stands Iām ā¦ yeah I donāt know what to order now.
Blockquote * Iāve successfully tested these passive PCIe PCB adapters with Gen4 SSDs, no PCIe Bus Errors after 24 h of sustained load: Delock Products 90091 Delock PCI Express 4.0 x8 Card to 2 x internal U.2 NVMe SFF-8639 - Bifurcation
They are no good in my situation, I need an NVMe to U2 solution.
You should make sure that your OEM systemās BIOS is at all even compatible with all third-party PCIe NVMe SSDs. There have been numerous cases where these kinds of systems have a white list in their BIOSes where the manufacturer blocks devices from third-party manufacturers from even showing up. Would never buy OEM systems if you like flexibility.
Depending on the BIOS, if the motherboard canāt establish a stable PCIe interface connection with a device it can happen that it just doesnāt work at all and it not just downgrades to PCIe Gen3 or Gen2.
Check if you can force the M.2 interfaces of the motherboard to Gen3 instead of āAutoā and try again.
The only buyable solution for adapting M.2 PCIe to U.2/U.3 PCIe Gen4 SSDs is one with an active M.2-to-Gen-Z adapter and an Gen-Z-to-SFF-8639 cable:
MCIO would be the better modern connector type for PCIe Gen4/5 but the corresponding parts donāt seem to be out yet. SFF-8654, 8643 or OCuLink (mechanical strength) are not that great for PCIe Gen4 and above.
What do you define as properly? Iām using the ones I posted earlier and havenāt noticed any issues. I donāt see an AER option in the BIOS but if I grep dmesg for it I get multiple AER enabled messages but no error messages.
pcieport 0000:00:01.1: AER: enabled with IRQ 28
-[0000:00]-+-00.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
+-00.2 Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
+-01.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
+-01.1-[01]----00.0 Intel Corporation NVMe DC SSD [3DNAND, Sentinel Rock Controller]
The first step is always asking yourself: āMight this be too good to be true?ā
How do I check if PCIe AER is working properly without having USD 500,000 signaling test equipment:
(There are parts with thousands of errors per second on one end of the spectrum and ones with only a single digit amount of errors per hour - BUT there are no completely passive adapter chains with PCIe Gen4 or above with cables that donāt introduce any PCIe Bus Errors at all)
Perform various extreme load tests on the connected SSD.
Check for PCIe Bus Errors via AER in operating system logs (on Windows these usually are WHEA ID 17).
If there are no errors at all with parts with previously thousands of errors per second then something is wrong, likely the BIOS not notifying the operating system of PCIe Bus Errors.
Check that the tested PCIe Interface is coming directly from the CPU and go through the BIOS to look for AER options, āAutoā (the usual default option) does not mean enabled most of the time. Also I have never seen logged PCIe Bus Errors on motherboard chipset PCIe interfaces, only direct CPU PCIe.
Why bother if no errors show up and drives seem to operate at their maximum speed?
