Wasn't quite sure what forum to post this in but here goes ;-;.
My friend passed me a PCI-E Expansion Card, and I've been having troubled getting the drivers to work (I think).
http://www.newegg.com/Product/Product.aspx?Item=N82E16815129016
The Card provides power to everything I plug into it but the devices aren't recognized in windows. Iv'e tried re-installing the card a few times using the drivers from the visiontek website, I have also checked that the card is firmly plugged into the PCI-E slot, and that everything is in the correct place. A couple re-installs in the card worked for a couple minutes but then stopped working.
Not sure where to go from this point, the imgur link is a ss of my device manager, any help would be appreciated.
http://imgur.com/Slql4i2
