1.4 Display Port KVM Switch - Single Monitor - Four Computer
USB Interface (5-gigabit or 10-gigabit):
10-gigabit
Problem:
I recently updated to this new KVM. My previous was the dual monitor of the same which ended up having USB passthrough issues. The PC worked fine with the old KVM (it might have been a pre-DP 1.4 model, can’t remember). The PC connects fine to the monitor directly. I just updated to all FIBBR cables, so, in this case a 1 meter and a 2 meter. On the occasions that it has connected, if I swap to my 2nd computer (mac - just upgraded to a Moshi cable and works great, worked poorly with previous) and I try to swap back, 100% chance it will not reconnect.
Some oddities that I’ve noticed:
It will usually show the mobo post sequence before disconnecting and never reconnecting
Monitor is a Neo G9 (you probably hate these by now) which goes to sleep rather quickly (sub-5 seconds)
Sometimes, if I go to different ports on my graphics card (RTX5080), it will connect (until I try to swap to another computer) and will either be at normal resolution or something that says that it is normal resolution but has black bands at the top and bottom.
Other Notes:
USB seems to be working fine on the transitions and reliably switches computers even if the monitor never connects.
Any mac connected to a USB hub connected to the KVM will not pick up any attached devices. This is a separate problem but of note. It seems to be an issue with macs only allowing a certain level of “recursion” (someone else’s term not mine) where the KVM shows up as multiple layers of USB hubs.
the fibbr 1m cables are sometimes a bit sus. they seem to be down bins of longer cables that failed and they just shortened them so they’re borderline.
id try a copper cable where that fiber cable is currently.
I have tried multiple copper cables. One cheap, one expensive, and the original Samsung. I know that these aren’t on your list of recommended cables but I would think that one or another would work at some point.
There are a lot of issues here that would benefit from a video showcasing what is wrong. Place a technical support ticket so we can get it documented appropriately:
Hi @Level1_Amber - I can open a support ticket, but, to be clear, I do not believe this to be a problem with your product. I would have opened a ticket if I did.
I posted in the forum hoping that you or someone else could provide some guidance about what I believe either to be a hardware issue with my PC or a setting that I have borked up somewhere. I also wanted to make clear that I have reduced the chances that it is cable-based by testing various combinations.
I am also only semi-versed in these types of problems and believe you and your community to be a stronger base of knowledge than I possess in this domain.
I’m happy to open a ticket if that’s where you believe the best opportunity for solution can be found but I also wanted to be clear that this is a me issue that I’m seeking help with.
Thank you for the help so far! I appreciate it. Please let me know as to the above.
Oh you don’t have to open a support ticket, good to have the link in case we do determine it’s the KVM.
Can you set this to 240Hz if it is not already? Because of how DSC works 240Hz is actually easier to obtain than 120. Also as wendell mentioned, sometimes there’s a bandwidth increase when using 1 fibbr in the first leg then 1 copper DP cable in the second leg of the connection.
@Level1_Amber - update on this. I’m sorry for taking so long. The issue was the motherboard. I knew that early x670s were iffy, at best, with memory. I also knew that both of the x670s that I had really disliked graphics cards. I got tired of the other issues as well as wanting, to, you know, use my 7200 mt/s ram at something over 3000. Replaced mobo w/ x870, all of the sudden, it works.
